Selecting wheels and tires
18 x 9.5 that is said to fit at all four corners on my car: https://www.oewheelsllc.com/CV05-180...C5-style-wheel
17 x 8.5 that is said to fit only the front: https://www.oewheelsllc.com/Corvette-C5-Wheel-chrome
Questions:
1. I've been very impressed with the Michelin Pilot Sports that I've had on my C4s, but I'd prefer to not limit myself too much with respect to tire selection. Does this suggest that I'll be better off with the 18 x 9.5 wheels at all four corners?
2. What size tire is ideally suited to an 18 x 9.5 wheel? I'd like to keep the O.D. as close to OEM as possible, to preserve speedometer accuracy.
3. What size tire is ideally suited to a 17 x 8.5 wheel?
4. Of those that are available to fit these wheels, what do y'all like for tires these days?
Many thanks in advance for any and all advice.
Live well,
SJW
Use this site to compare tire sizes to retain or get close to the factory rev/mile: https://tiresize.com/calculator/
I can't help you on your other questions. Since our's is going to be a daily driver, our tire selection focus is different. But what I am seeing is that you need to select your tire for you situation then see what sizes they are available in. The 18x9.5's all around might be a better solution for you. We have been looking at 16x9.5 and 17x9.5 rims and the tire selection isn't quite as good as I expected. Wheel and tire sizes have obviously grown over the years.
I went with 18"x9.5" +40 rims on my 86 with 255x40zr18 tires. Fits like the oem's did but a whole lot better selection today.
I found a place with a range of rims for the early C4's with the correct offset so you don't need spacers. I don't know if it's ethical to post the site or not but if you send me a pm I'll pass along the web info. No connection to them other than I bought my rims there in the past.
I don't shop Tire/Rack but they seem to display 26 tire choices.
For an idea of profile maybe check this ZR-1 that used to live in MD that had 285/35-18 on the front. You should have no trouble finding other snapshots of C4's with 285/35-18.
An ideal wheel might be 10" @ 50 mm
https://www.corvetteforum.com/forums...ot-sports.html
Many ZR-1 run a 285/35 on the front - here's another with 18 X 10 Shelby
http://www.zr1.net/forum/showthread....light=285%2F35
9.5's will work all the way around . I am considering going that route since their are not a lot choices for the 285s, and having tires that can be rotated.
I checked the stock size listed on VetteFacts.com which showed 275/40ZR-17. After spending time on that site linked in this thread, TireSize.com I think I'm going with 245/45R17 tires. The only difference between the 245 and the 275 is 1.2" in width, every other measure (shown in the tire calculator) is the same between them. The 255/45R17 that the PO had mounted were larger in diameter and circumference which I think would impact the speedo. Given the amount of rubber these cars have I don't think I'll notice any difference in performance in daily driving. There are way more choices and more tires at lower prices in the 245 size. Have I missed anything obvious?
That 17x8.5 has 2mm too much offset, but that's probably not enough to worry about. Not sure why they'd say they would only fit the fronts. They'll fit all four corners. But I think you'll regret not going to 9.5s.
Questions:
The best tire size will be 275/40/17 if you have 9.5" wheels, and 245/45/17 if you have 8.5" wheels. In 93, your car either came with the "staggered" width of 8.5 front and 9.5 rear, or it came with 9.5 at all four corners if it had the Z07 performance suspension option. So you need to verify your wheel widths first, and choose tires accordingly. The good news is that there are lots of choices in either tire size, and plenty that have size options in both sizes if you have the staggered wheel widths.
Live well,
SJW
Last night I was entertaining myself by looking up as many of my car's RPO codes as I could find and XAA was one. That one is "XAA - Front Tire (P255/45ZR17)", yet more conflicting information. I did find the code "QB6 - 17x8.5 Front and 17x9.5 Rear Aluminum Styled Wheels" so at least that checks out.
On the staggered wheel-width setups, it's probably better for most people to move to 245/45 front tires and 275/40 rear tires. There are a lot more tire options in those sizes, and those sizes are more appropriate widths for those wheel sizes.
I've been thinking about going to 245/45 tires on the front, just as you said, to improve the range of available tires but also because I'm thinking it might lessen harshness. As an old guy, I'm not so much interested in absolute performance but I also don't want to emasculate the bull so I was thinking the 245/45 might be a good compromise since it keeps all the dimensions of the 275/40 with the exception of being 1.2" narrower.
Right now my car has the Z06 wheels and those 13 1/2" rear tires make the car feel like a roller skate with steel wheels. It's not so bad on a smooth road but there aren't many smooth roads in New Jersey.
BUT...don't overlook tire pressures. Lots of people put much wider tires on their cars but run the same pressures as they did with their prior narrower wheels and tires. That's not how this works! The whole point of going with wider wheels and tires is to put more rubber contact patch on the ground, but if you don't reduce pressures then you lose at least some of that advantage. So if, for example, you ran 35psi with 9.5" wheels and 275 tires out back, then you can probably run 30 psi with 315s, or maybe even less. That also has the benefit of getting you some of your ride quality back, so that it doesn't feel like a roller skate.
A 245/45R17 tire is meant to fit a 7.5-9" wide wheel. This means a good fit on your 8.5" wide front wheels, but not your 9.5" rear wheels. The lip of the rear wheel will stick out beyond the tire sidewall and be highly subject to curb rash. Yes, there are tons of 245/45R17 tires out there as they fit a lot of Mustangs. A good tire in that size isn't that much less expensive ($20 or less in many cases) than a 275/40R17 that will fit the rear properly. 285/40R17 are less common and more expensive. My car was built with 9.5" wheels front and rear so I have 275s all around.
I checked the pressure in the tires when I brought it home and the PO has all 4 at about 34.
Looking forward to their arrival, and to putting the floor jack to good use, hopefully as soon as next week. I'm tired of looking at the peeling chrome in the barrels of the wheels that are on the car now, and the tires are tired (pun intended).
Live well,
SJW
I also have to find a used front rim as one of mine is so badly damaged it's not worth fixing
