dumbest tech question ever
Old Nov 8, 2002 | 11:03 PM
RocketSled's Avatar
RocketSled
Default Re: dumbest tech question ever (ncider)
If you've got four jackstands, you can carefully lift the seam at the midpoint of the door and place a jackstand at both 'jack here' points. That gets ALL the wheels off the ground. Make sure you a) get the jack lifting at the right point (the fibreglass will bend slightly at that area) and don't get the jack too far back to keep it away from the footwell and various lines that are tucked up there.
