Where do you order Gears?
Old Nov 6, 2002 | 10:45 PM
Black96Corvette's Avatar
Black96Corvette
Default Where do you order Gears?
Where can I order a set of GEARS ( Not the entire differentail ). I'm going to be staying with my Dana 36 but would like 3.73's or 3.75's to be installed over the winter. If anyone can chime in to help thatd be great! Also what ways can a Dana 36 be made stronger? What are the prices for a Gear change ( gears themselves not installation ). Are the gears themselves Ring & Pinions?
Michael
Old Nov 6, 2002 | 10:49 PM
vader86's Avatar
vader86
Default Re: Where do you order Gears? (Black96Corvette)
The Gears are just ring and pinions, if youre keeping the same carrier.
You cant make the D36 stronger, you have to move up to D44, just dont run drag slicks and youll be fine.
not quite sure on prices, maybe $700?
Old Nov 6, 2002 | 11:04 PM
gtsyellow's Avatar
gtsyellow
Default Re: Where do you order Gears? (vader86)
talk to aqua metalic here on the forum, he's opening a shop soon & has great prices and access on gears & would probably rebuild your entire pumpkin for you if need be.
Old Nov 6, 2002 | 11:13 PM
thetorch's Avatar
thetorch
http://www.reiderracing.com
Ask for Barney. Excellent prices and service not to mention extremely knowledgable.
Old Nov 6, 2002 | 11:57 PM
Black96Corvette
700$ for just gears? I thought Richmonds were like 280$ for gears... that is real steep for just the ring and pinion.
Old Nov 7, 2002 | 12:07 AM
vader86's Avatar
vader86
oops that would be $700 installed or thereabouts
base prices for SLP and others are about $200-300
Old Nov 7, 2002 | 02:53 AM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
Depends on the rear end. I have found the Dana 44 rear to be cheaper to get parts for. Try Toms Differentials on the net. http://www.tomsdifferentials.com. He's a pretty sharp guy and his prices are reasonable. Try Randys ring and pinion also http://www.diferentials.com. They are not as knowlegeable as Tom with vettes but their prices and parts are good.
Old Nov 7, 2002 | 05:02 AM
93 ragtop's Avatar
93 ragtop
As far as making the 36 stronger, there is a HD carrier that you can add. Zip and Ickerds both sell it. Basicially what it does is, it has plates welded in that put pressure on the bearing caps to help prevent them from moving. This already comes on a 44 but did not come on a 36. I think it sells for around $300.00 exchange.
To Where do you order Gears?
