Throttle body
Old Jun 14, 2019 | 10:29 AM
fredk's Avatar
fredk
Default Throttle body
I pulled my throttle body off my 93 to give it a good cleaning. I am having a hard time finding gaskets as I want to pull the throttle body completely apart any suggestions ??
Old Jun 14, 2019 | 11:19 AM
vette196's Avatar
vette196
I'm with you on this,wondering what gasket to use/where to get the TB plate gasket...
additional question: what size gasket to use on an intake ported to 58mm and the TB is 48mm
Old Jun 15, 2019 | 10:34 AM
fredk's Avatar
fredk
I found them at Jeg's
Old Jun 15, 2019 | 10:42 PM
belairbrian's Avatar
belairbrian
I used the Standard Motor Products 2045 set. Price varies widely depending on source.
If you just need a TB to intake a Fel Pro 60655 (about $3 on amazon)
Old Jun 16, 2019 | 10:28 AM
fredk's Avatar
fredk
Thanks I ordered from Jeg's yesterday.
Old Jun 16, 2019 | 06:39 PM
Glassman89's Avatar
Glassman89
NAPA can order what you need.
Old Jun 23, 2019 | 05:34 PM
DAVECAD2.0's Avatar
DAVECAD2.0
Default 1992 lt1
I used BBK #1583 for 52mm. ebay $20.00.Free shipping.
Old Jun 23, 2019 | 07:48 PM
aklim's Avatar
aklim
To clean it throughly, I would take the IAC off, clean the pintle with a gentle mist of brake cleaner and wipe it clean. IAC housing should be off too for easier access to the passages. Might as well cut up the IAC housing and to the coolant bypass mod. Don't forget the top plate. DO NOT PUSH THE IAC PINTLE IN OR PULL IT OUT
Old Jun 25, 2019 | 09:27 AM
fredk's Avatar
fredk
That's my plan for the TB, all apart. Just received my parts except my injectors. Thank you
To Throttle body
