C4 headlights
Old Jun 14, 2019 | 08:48 PM
Tvette99's Avatar
Tvette99
Default C4 headlights
Ok for the love of god you guys I repaired my headlights or atleast i thought i did however one of them now is closing when it should be opening and vice versa. Now the only thing i can think of is maybe I put the brushes in backwards when I had the motor apart would that cause this to happen ? Or if you have any other suggestions i would appreciate it because I'm super duper angry right now and have been fighting with this pos all freaking day
Old Jun 14, 2019 | 10:05 PM
Pwnage1337's Avatar
Pwnage1337
They are DC motors right?
Just switch the ground with the positive on the connection to the motor? Any chance that you have the connector hooked up wrong? I'm not sure if that's even possible
Old Jun 14, 2019 | 10:25 PM
Tvette99's Avatar
Tvette99
By switching the wires will it cause it to go in reverse ? Id rather not have to do this ive read this is a very common problem but havent found any fricking resolution yet. Just looked it up dc current only works 1 way switching wires will do exactly jack and **** and jack left town
Old Jun 15, 2019 | 12:06 AM
Pwnage1337's Avatar
Pwnage1337
I am relatively certain that if you flip the leads on a DC motor it will run the opposite direction lol
Old Jun 15, 2019 | 10:25 AM
Tvette99's Avatar
Tvette99
Ok so out of sheer curiosity I did use jumpers to the different terminals and the headlights are both now working in unison???? What did in do wrong with regards to wiring to cause it to do this ????
Old Jun 15, 2019 | 02:02 PM
Pwnage1337's Avatar
Pwnage1337
Are you saying that you just jumped 12v positive and ground from the battery and they move in the right direction?
Old Jun 15, 2019 | 09:54 PM
Tvette99's Avatar
Tvette99
I switched the wires running to the headlight motor
Old Jun 16, 2019 | 12:08 PM
Pwnage1337's Avatar
Pwnage1337
Looks like Jack must have came back to town
Old Jun 16, 2019 | 07:33 PM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
Ah, no. Swap DC polarity, motor goes the opposite direction, if it's a brushed motor. You may have found something referring to AC motor. Or, just someone who is plain wrong.
A brushless motor would either do nothing or blow its controller.
Old Jun 16, 2019 | 10:14 PM
Hot Rod Roy's Avatar
Hot Rod Roy
When you rebuilt your motor, did you remove the magnets from the housing? Reversing the positions of the magnets will make the motor run backwards.
Old Jun 19, 2019 | 10:48 PM
Tvette99's Avatar
Tvette99
The magnets I didn't touch the brushes came out yes
To C4 headlights
