Headers
Old Nov 7, 2002 | 01:19 PM
Corvette0096's Avatar
Corvette0096
Default Headers
This is going to be close!! Are you guy with autos wrapping your y pipes? I wish I would have read Scorps post about putting on two sets of header gaskets :cry Any body have ploblem with getting them to seal?
TIA
Old Nov 7, 2002 | 01:21 PM
scorp508's Avatar
scorp508
Test fit your y-pipe first. I had to use a mallet to bang mine in a little in a couple of spots so that it wouldn't make contact with the oilpan on the overdrive unit of my 4+3.
Old Nov 8, 2002 | 06:35 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Re: Headers (corvette0096)
Lot's of heat around everything...any problems with the heat?????
thank-you
:smash:
oldace84's Avatar
oldace84
thank-you
:smash:
Old Nov 8, 2002 | 10:45 PM
RocketSled's Avatar
RocketSled
Hmm, I didn't wrap the headers. But I _did_ insulate a brand spankin new NAPA starter as It didn't want to deal with is a second time.
It's now the THIRD friggen time I get to swap the starter out. Second NAPA starter was inadequate to task.
Also, very soon after startup, I noticed the left hand header flange rubbed a slot in the tranny tunnel. I REALLY got worried about that, but after 2500 miles, it didn't get any worse.
Also, compared to a non-ceramic coated header that was fibreglass wrapped, your Ceramic coated headers will feel much cooler in the passenger compartment.
Old Nov 8, 2002 | 10:53 PM
corvette1990's Avatar
corvette1990
Default Re: Headers (RocketSled)
I also had to bang/testfit the Y pipe first. The coating was real thick and a problem. I also Thermo tec blanketed the starter a year ago and have had no problem. Other than melting a starter wire, that moved after a month, and the plug wire that I forgot to put back in the loom. The black plastic cover for the wiring harness seems to be real brittle these days, near the brake booster. But knock on wood, the header gasket to block has been perfect. :yesnod:
Old Nov 8, 2002 | 10:59 PM
gtsyellow's Avatar
gtsyellow
Default Re: Headers (corvette1990)
i tried telling you to buy the double thick aluminum gaskets :) see how the ones you have work & don't bother unless you have leaking issues. i think the next time i order from summit i'll get a extra set to keep on hand...who know someone might need them :D
Old Nov 9, 2002 | 11:54 AM
torqueman2002's Avatar
torqueman2002
The manifold flange on the Headman Headers I have has ~1/8" gap at 1 end.
The machine shop that did my 383 said they cut the flange in 2 places with a hack saw. One cut between the 1st pipe and the two center pipes and another cut between the last pipe and the two center pipes.
This allows the flanges to bolt up to the heads with less twisting and flexing. I used Stage 8 header bolts to clamp everything down. :smash:
Happy motoring!
:chevy
To Headers
