Blower issues
Old Jun 22, 2019 | 06:54 PM
Rcajun's Avatar
Rcajun
7th Gear
Default Blower issues
A/C on Max cool air blows down what could be issue ? This an 84 coup
Old Jun 22, 2019 | 07:35 PM
Vette_DD's Avatar
Vette_DD
Ask the C4 folks.
https://www.corvetteforum.com/forums...discussion-34/
Old Jun 22, 2019 | 09:17 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
I agree with Vette DD. Check in with the C4 forum. A lot of knowledgeable folks there. Welcome to Corvette Forum!
Old Jun 22, 2019 | 09:59 PM
Moved to C4 Tech.
Old Jun 23, 2019 | 01:10 AM
Hot Rod Roy's Avatar
Hot Rod Roy
Originally Posted by Rcajun
A/C on Max cool air blows down what could be issue ? This an 84 coupe.
Are you saying that the NORM position works properly, that you get cool air thru the dashboard vents when you select NORM? But when you select MAX, the cool air blows onto the floor?
Old Jun 23, 2019 | 04:02 PM
Rcajun's Avatar
Rcajun
7th Gear
Yes air doesn’t come out the top vent floor only
Old Jun 23, 2019 | 07:27 PM
Hot Rod Roy
Your answer confuses me.
Old Jun 23, 2019 | 07:49 PM
GregMartin's Avatar
GregMartin
The FSM describes in quite a lot of detail what colour vacuum line operates what flap/door for your heating, cooling and vent arrangement. Pretty good bet that there is a problem in one of those vacuum circuits.
Old Jun 23, 2019 | 09:06 PM
Rcajun's Avatar
Rcajun
7th Gear
sorry for the confusion / at first air was only coming out at the bottom vent on fan high, max cool / now air comes out middle grilles and bottom grille on passenger side at same time , trying to only have air come out top vents only . is it suppose to operate like that ?
To Blower issues
