Please help. Intermittent vibration '94 6-spd
Old Jun 23, 2019 | 08:39 PM
Furioso's Avatar
Furioso
Default Please help. Intermittent vibration '94 6-spd
(I had a thread that was hijacked. Forgive me for reposting.)
This is a new problem, as I've had the car for 2 years and it just has begun:
Annoying intermittent vibration felt in shifter when in gear. Cycles on and off, 5 seconds vibration, 5 seconds gone.
Definitely in the driveline. Feels like a bad bearing.
At all speeds.
Vanishes when I put in clutch.
The vibration is most strongly felt in the shifter.
But it of course I feel it throughout the car.
It disappears when rolling in neutral.
Does not seem to be the clutch.
It recedes almost completely, but not quite, when the clutch is depressed.
This is a new problem, as I've had the car for 2 years.
Replaced U-joints and rear bearings. 6 month old tires all around.
Maddening. Please help me diagnose.
Thank you so much.
~Ricardo Furioso
ps-I'm sorry I've had to repost this, but I still can't figure out what it is. Thanks again for suggestions.
Old Jun 28, 2019 | 12:47 AM
Furioso's Avatar
Furioso
Should I give up?
Anybody?
Old Jun 28, 2019 | 05:45 AM
bjankuski's Avatar
bjankuski
I cannot tell from your post, did you check or replace the driveshaft u joints, or rear axle u joints? If the clutch is engaged, and you play with the throttle to apply no load to the driveshaft, does the problem change? Are the c beam bolts tight?
Old Jul 17, 2019 | 11:59 AM
Furioso's Avatar
Furioso
I replaced u-joints and a rear bearing. It now appears that the vibration is coming when the AC compressor cycles on. Seems to be motor mounts.
Any thoughts?
Old Jul 17, 2019 | 02:05 PM
jayjones's Avatar
jayjones
Check the sticky links and search the forum. Tons of good info is on this website if you use it like an archive. You can probably find the solution to most problems while waiting on a response.
Old Jul 20, 2019 | 02:24 PM
ctmccloskey's Avatar
ctmccloskey
The little bushing or bearing they use on the Clutch pilot shaft can go bad and make some strange sounds. When you push the clutch in it could stop the noise. I have seen this happen on other manual transmission vehicles. The only way to fix it is to remove the transmission and install a new one in the flywheel. I found this description for you.
When the clutch is disengaged, the transmission's input shaft and the engine's crankshaft are rotating at different speeds. The pilot bearing allows for this difference. This is why a faulty pilot bearing makes its most noise when the clutch pedal is completely depressed and the clutch itself is completely disengaged.
I have heard noise that was from the pilot bearing that went away when you let the clutch out. I guess it happens either way.
Just another wacky idea!
Best regards,
Chris
Old Jul 21, 2019 | 10:25 AM
knikula's Avatar
knikula
few guesses: fluid level in the trans low, causing a trans bearing to spin in it's bore? Pitted bearings in the trans causing the same thing? Or the Thrust bearing on the crankshaft bad?
I'd check the trans fluid level, and try disconnecting the A/C compressor clutch to see if it makes a difference....
Good luck.
To Please help. Intermittent vibration '94 6-spd
