RPM Question
Old Jun 25, 2019 | 12:54 PM
SULLY_PA's Avatar
SULLY_PA
Default RPM Question
I just had the 700R4 rebuilt in my 1990 and on the highway at 60\65 I'm at 3000 RPM does that seem right ?
Old Jun 25, 2019 | 12:57 PM
vader86's Avatar
vader86
In what gear?
Old Jun 25, 2019 | 01:02 PM
SULLY_PA's Avatar
SULLY_PA
Well i have it in OD ....felt like it went in.
Old Jun 25, 2019 | 01:05 PM
cdm747's Avatar
cdm747
St. Jude Donor '17-'18-'19-'20-'21-'22
In my 88 on the interstate i am around 2200 RPM at about 78mph. Something isn't right with yours if your truly in OD.
Old Jun 25, 2019 | 01:08 PM
Kevova's Avatar
Kevova
Stock gear it's not.in overdrive it's in 3rd. Make sure shifter cable correctly adjusted. Drive it in D (3rd) see what RPMs are the move shift to OD see if it will shift.
Old Jun 25, 2019 | 01:27 PM
WVZR-1's Avatar
WVZR-1
Originally Posted by SULLY_PA
I just had the 700R4 rebuilt in my 1990 and on the highway at 60\65 I'm at 3000 RPMS does that seem right ?
You've many things to consider! A '90 is well known for tach error. If you have C68 check with the AC Control. With the KEY- ON but NOT RUNNING > does the tach needle park @ 0? They 'rebuilt' your unit and used your VSS drive/driven etc?
Old Jun 25, 2019 | 01:39 PM
SULLY_PA's Avatar
SULLY_PA
Well I was just reading about the 90' having tach issues ....So I better check that out first .....After considering that issue ..... I called the shop who did my rebuild and he said the tach was off sometimes by a lot but averaged 1k off with his testing equipment and that he forgot to tell me......this is my 3rd Vette' but my first C4 ....thanks for the input all!
Old Jun 25, 2019 | 02:55 PM
aklim's Avatar
aklim
Instead of guessing, perhaps a scanner can tell you this and so much more? Not a code reader, a scanner.
Old Jun 25, 2019 | 03:27 PM
SULLY_PA's Avatar
SULLY_PA
Who said anything about guessing? I'm going to hook my laptop up and check it out. Thanks ...
Old Jun 25, 2019 | 04:15 PM
WVZR-1's Avatar
WVZR-1
SMART A$$
Well done!!
Checking TCC operation and complete operation I'd think a 'do soon'! KEY ON - NOT RUNNING that parks @ 0 hints reliable. KEY OFF it can park any where!!
Old Jun 25, 2019 | 04:28 PM
aklim's Avatar
aklim
Assuming you have a way to get data, you are ahead of many
Old Jun 25, 2019 | 05:01 PM
SULLY_PA's Avatar
SULLY_PA
Well I'm going to try with Tunerpro RT but I've heard that may have issues with reading 90' data ...if so I'll download Winaldl and see how that goes
To RPM Question
