84 AC compressor sensor
Old Jun 28, 2019 | 04:24 PM
Sliver84's Avatar
Sliver84
Default 84 AC compressor sensor
Does anyone have a source for the sensor that comes out the back of the AC hose on the back of the compressor near the driver side valve cover on an 84? I have looked everywhere and can only find used ones. The gm part number is 10007052. Mine is missing for some reason due to the previous owner and I am trying to get the AC going again.
Old Jun 28, 2019 | 04:46 PM
Hot Rod Roy's Avatar
Hot Rod Roy
FYI, that is a "high pressure safety sensor", and your a/c will work without that sensor, although that shouldn't be a permanent situation. That is a NC (normally closed) switch that is closed at all times, except when the pressure in the system exceeds about 400 psi. That is a delicate switch, and that is why I traded positions of my valve covers, to move my oil filler to the drivers side on my '84.
Old Jun 28, 2019 | 04:58 PM
Sliver84's Avatar
Sliver84
Thanks for the info, mine was snapped off at the hose, fitting and all. Finding a replacement hose was easy but I can't seem to find a new sensor.
To 84 AC compressor sensor
