Some intersting gross vs wheel HP numbers
Old Jul 1, 2019 | 09:10 AM
bjankuski's Avatar
bjankuski
Default Some intersting gross vs wheel HP numbers
I tune part time (for fun) at a local dyno shop and I am always looking for and comparing engine dyno data to actual wheel HP. I do not always have this information but when I do have something relevant I like to check numbers. Last week I tuned a 1995 LT1 auto vette that had a mild 355 built that on the engine dyno made 416 HP. I am sure it was run with headers on the engine dyno and a holley EFI stand alone. (Did not see the test but know the dyno shop)
On the chassis dyno the car made 342 RWHP after I was all done tuning it with HP tuners and a OBDII conversion system. (Torque head if you care). In this situation the vette had 3.07 gears/auto trans/stock convertor/ and headers no CATS free flowing exhaust.
That works out to a 18% drivetrain loss. Just some interesting info.
I have seen drivetrain losses as high as 30% with very high stall convertors but this 18% fell right in line with what I expected.
Old Jul 1, 2019 | 09:31 AM
fredk's Avatar
fredk
Good information !!!
Old Jul 1, 2019 | 10:27 AM
Aardwolf's Avatar
Aardwolf
All that free HP if efficiency could be increased!
Is there an auto or clutchless transmission that isn't eight grand plus with less percent loss?
Old Jul 1, 2019 | 10:33 AM
84 4+3's Avatar
84 4+3
So the 20% guess is reasonably close on a stockish setup. Nice info to know.
Old Jul 1, 2019 | 01:43 PM
DGXR's Avatar
DGXR
Any numbers for a manual transmission LT1 C4?
Old Jul 1, 2019 | 02:38 PM
bjankuski's Avatar
bjankuski
I don't really know, other then a manual trans which usually is about 3 to 5 percent less loss.
Old Jul 1, 2019 | 05:56 PM
Aardwolf's Avatar
Aardwolf
I wonder if something like the g force g101a could work and what it would have for loss. There's one on Ebay for $2500.
Old Jul 1, 2019 | 07:35 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I read somewhere that one could expect ~15% DT loss with a stick shift and ~17% with an A4.
When drag racing my prior 35th anni., with a 2,000TC that 17% came out on the money.
One night at Englishtown some guy pulled in with a dyno so I got the RWHP numbers and I had trap speed as well as weight to calculate CHP and the difference was exactly 17% DT loss. That was on a 300chp TPI motor.
Old Jul 1, 2019 | 08:00 PM
Aardwolf's Avatar
Aardwolf
Has there been a difference in percent loss on newer versus older?
Old Jul 1, 2019 | 08:20 PM
84 4+3's Avatar
84 4+3
6/8speeds area little better. The ZF auto in the hellcats are supposedly a little better still... around 12% iirc.
Old Jul 1, 2019 | 11:20 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
In my observation, nearly all modern stick shift cars are close to 10% loss, chp to rwhp.
Cool data in the first post! Love the real, actual numbers!
To Some intersting gross vs wheel HP numbers
