Yea, yea . . . another antenna thread.
Old Jul 1, 2019 | 01:15 PM
rusty76's Avatar
rusty76
Default Yea, yea . . . another antenna thread.
I'm wading my way through 479 posts after doing a search about my antenna problem so I figured I'd post a new thread now so it can percolate while I'm reading.
This is my first 'vette so I'm a newb, I don't know much. My antenna works . . . it goes up and down, and up and down, it goes up all the way but not all the way down. When it stops there is still about 12 to 14 " sticking up. The segments of the antenna move freely so that's not the problem. Is this indicative of damage to the track on the antenna? Is it likely that a new mast will fix the issue? I've been studying the manual but I haven't found anything that specifically describes this symptom. Since the motor is still working if a new mast will fix it I'll probably do that. If I'm looking at a new antenna unit then I may just go non-retractable and fix the power antenna at my leisure for later installation.
Thank you for reading this and for any input you might have.
Old Jul 1, 2019 | 01:34 PM
playsdixie's Avatar
playsdixie
welcome....a year would help with your problems when you post.....can't help you too much as I eliminated mine for a in-dash and sealed the antenna hole....but I do know that most work off a "ribbon" which is replaceable....sounds like that's your problem....
Old Jul 1, 2019 | 01:49 PM
Tod Stiles's Avatar
Tod Stiles
Yes, this sounds like the antenna mast ribbon has a problem. Not expensive and not too bad to fix. You'd have to take it out anyway to replace it with a fixed mast, so why not just fix it?
The ribbon breaking or otherwise not working was kinda a common problem with this mast for most GM cars. Fixed many back in the day. Good luck with the repair what ever you decide!
Old Jul 1, 2019 | 03:42 PM
rusty76's Avatar
rusty76
Sorry, a '93 coupe, my bad.
Thanks for the reply.
Old Jul 1, 2019 | 03:48 PM
rusty76's Avatar
rusty76
Assuming it's the ribbon, are those available by themselves or only as a part of the mast assembly I've seen advertised? I just did a quick check on gm parts direct and they only showed the whole assembly.
Old Jul 1, 2019 | 05:44 PM
Ed Ramberger's Avatar
Ed Ramberger
you have to take the motor out, open it up and replace the mast/ribbon assy. Some of the old ribbon is most likely broken off inside the motor. antennamastsrus.com is the best place to get it from in my experience. If the motor has plastic studs melted over to retain the antenna cover, you drill the tips off and use little screws to reassemble.
Old Jul 1, 2019 | 07:42 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I recently replaced the entire antenna in my '88 and it was a freakin' night-mare. Considering the difficulty I just replaced the entire unit.
Fortunately for you it will be rather simple in your '93. Check out the utube vids on "how to".
Old Jul 1, 2019 | 09:30 PM
rusty76's Avatar
rusty76
Thanks for the replies. I was checking out masts are us. I'll have a look on Youtube. I guess I'll wait till the summer is over before I tear into it. No sense having the car down during nice driving weather.
Old Jan 19, 2020 | 07:12 PM
rusty76's Avatar
rusty76
Today I started messing with the antenna mast on my '93 so I figured I'd update this thread.
I started by pushing the antenna all the way down so I could easily get a pair of right angle needle points onto the nut to get it off. When I did this it was obvious that the ribbon teeth were engaged with the drive wheel on the motor because I could feel the resistance. I was then able to pop the mast out. I expected to see obvious evidence of damage to the tape but I didn't. I wiped off the ribbon pretty well and did a closer examination, there are no damaged teeth on the ribbon. I took a good look at the leading end of the tape and it had a factory end on it. It didn't appear to have been broken off.
I'm thinking one of two things is happening.
  1. Someone before me replaced the mast and didn't remove a broken section from the housing before installing the new mast and it's preventing the mast from fully retracting. Since I was able to easily push the mast all the way down I'm not sure that's what's happening.
  2. Someone replaced the mast but didn't get it correctly threaded into the housing so it never fully retracted. I'm wondering about this because I saw references to this happening while researching the antenna issue. I don't remember where I read about or watched it.
Before I decide to remove the motor assembly I think I might put the mast back in and mess with it to see if I can come to a conclusion about what's going on.
Old Jan 20, 2020 | 12:09 AM
Fiberbundle's Avatar
Fiberbundle
You are probably right on the call that someone try to replace it. Unfortunately some of the vendors make it sound like all you have to do is take the old one out and slip the new one in but too often there is the broken end remaining in the actual motor and this results in what you are experiencing. I had the same issue and once I removed the motor from the car, opened it up and removed the broken piece, the new one worked perfectly.
it is not a hard job, but can be a pain to accomplish since they did not make it easy to get in there.
Old Jan 20, 2020 | 12:34 AM
Hot Rod Roy's Avatar
Hot Rod Roy
After you get that under control, and want to get away from the incessant up-down-up-down-up-down-up-down, here's how I modified mine:
https://www.corvetteforum.com/forums...post1600804607
Old Jan 20, 2020 | 08:58 AM
rusty76's Avatar
rusty76
Thanks Roy, I subscribed to that thread. I watched a video of adding that switch on YouTube and thought it was a good idea. One question, you say you only ran one wire and picked up power from an orange wire in the console. Did you just cap off the other end of the wire you cut to the relay in the bin?
Thanks.
Old Jan 20, 2020 | 09:10 AM
rusty76's Avatar
rusty76
Yea, I've watched videos of removing the motor assembly which is why I've decided to try to get it to function correctly by putting the mast back in BEFORE I pull the motor, couldn't hurt to try.
Just sitting here thinking about it, I'm thinking I'd better spend some time with the mast and a heat gun to try to get the tape straight again. I doubt I'll be able to get the tape fed into the motor correctly with it curled up like it is right now.
Old Jan 20, 2020 | 03:53 PM
Hot Rod Roy
What is the address of the video you watched? I haven't found one that describes cutting the orange wire, which is definitely the better way to do it! I've only found info on cutting the pink wire, which is NOT the same!
You say you only ran one wire and picked up power from an orange wire in the console. Did you just cap off the other end of the wire you cut to the relay in the bin?
Yes
Old Jan 20, 2020 | 04:44 PM
rusty76's Avatar
rusty76
Yes
I'll try to find it this evening. Don't hold me to what color wire it was, I'm old and remember things wrong sometimes. I thought I recalled you mentioned orange in your post on the other thread. Now I'm thoroughly confused.
Old Jan 20, 2020 | 05:30 PM
rusty76's Avatar
rusty76
Hot Rod Roy, I found the video I watched. That one caught my attention because it was for a '93 which is what I have. This guy cut the pink wire to splice in his switch.
Old Jan 20, 2020 | 10:42 PM
Hot Rod Roy
I thought so. Please review my link in post #11, above.
To Yea, yea . . . another antenna thread.
Old Jan 20, 2020 | 11:22 PM
rusty76's Avatar
rusty76
I read your link last night before I replied. My issue was I couldn't remember which color the guy in the video spliced into until I found it again.
Let me make sure I understand.
Using the method in the video if you splice a switch into the pink line, when you throw the switch the mast will retract and stay retracted until you flipped the switch again.
Using the method you outlined when you flip the switch, spliced into the orange wire, the mast will stop wherever it is in it's cycle and stay there until you flip the switch again?
If I do understand correctly . . . maybe I need 2 switches??
Old Jan 21, 2020 | 01:17 AM
Hot Rod Roy
You don't need two switches.
With the switch in the PINK wire:
Switch ON . . . Fully up when the stereo is on; fully down when the stereo is off.
Switch OFF . . . Antenna goes fully down, and stays down at all times. No intermediate antenna positions are possible. Fully up or fully down only!
With the switch in the ORANGE wire:
Switch ON . . . Antenna goes fully up when you turn on the stereo. Antenna goes fully down when you turn off the stereo. You can "park" the antenna at any height by turning the switch OFF at your chosen height.
Switch OFF . . . Antenna stays where it is regardless of whether the stereo is on or off. If you want the antenna to stay down, turn the switch OFF before you turn on your stereo.
Old Sep 16, 2022 | 05:15 PM
1985 Vette's Avatar
1985 Vette
I also replaced the entire antenna in my 88 a few months ago and it was not fun. My least favorite part is cutting my arm up removing the rear taillights so you can access one bolt that holds the antenna in place. I plan on rebuilding my old one to keep as a spare. I have checked recently, and I can't find a complete antenna assembly, but I can find the rebuild kits.
