Speedbleeder to bleed clutch?
I figured once the air was bled the fluid would stop coming through but I put about 3 quarts(just pouring the fluid from the bleeder bottle back into the bottle I’m using to fill the clutch master) and it just keeps going through the system. With the bleeder tight the pedal has plenty of pressure though. No leaks btw.
Background: 4+3 with speedway hydraulic TOB behind an ls.
Clutch is an oem replacement for a 2nd gen camaro and Sachs 1050 flywheel.
Stock replacement c4 clutch master.
Pedal pressure feels like even more than the factory set up so this should be fun to drive 🤷*♂️
