Intermittent Code 36 ???
Old Nov 8, 2002 | 07:44 AM
GlennS87's Avatar
GlennS87
Default Intermittent Code 36 ???
I know this is a fault in the MAF burnoff circuit but can anything other than a faulty relay cause this? I replaced both relays about 2 months ago. I have a de-screened MAF that has been working fine for years on the car. I have a Wells MAF also but when I use it I get an intermittent code 34.
Thanks in advance
Old Nov 8, 2002 | 08:13 AM
Vic'89's Avatar
Vic'89
Default Re: Intermittent Code 36 ??? (GlennS87)
Glenn
The code 36 is usually the MAF sensor relays, but can also be a bad ECM.
Does the car stumble as soon as the code 36 is activated ?
Vic
Old Nov 8, 2002 | 10:34 AM
GlennS87's Avatar
GlennS87
Default Re: Intermittent Code 36 ??? (Vic'89)
Vic,
It stumbles as soon as the service engine light comes on. It goes into limp home mode. Sometimes if I continue driving it sometimes goes away. In other cases, if I shut it down wait a minute and restart, it will go away.
I have a Wells MAF that I could put on which I believes eliminates the burnoff functionality by using a resistor of some sort, but I think I need to play with the TPS to make it work because I get an occasional code MAH high voltage code. (I forget if that's 33 or 34)
Are you going to e-town tomorrow?
Old Nov 10, 2002 | 08:11 PM
sailrmon's Avatar
sailrmon
If you still have the old ecm part#1227165 I would suspect it.When mine went out the symptoms were as you discribed.Apparently the drivers are prone to fail in these old ecms.The new and improved ecm part#is 16198259 Good luck!! :flag
Old Nov 10, 2002 | 11:04 PM
GlennS87's Avatar
GlennS87
Default Re: Intermittent Code 36 ??? (sailrmon)
Sailrmon,
That could definitely be it. Although I replaced the ECM about 2 years ago. I haven't gotten a code 36 in awhile, but I got a code 42 yesterday.
To Intermittent Code 36 ???
