My heads had a 58 cc volume. I had the heads milled flat, but don’t know how much was milled off, so I don’t know what volume they are now. Would it be same to use 57 for calculations, or would they be less then 57. I know without the mill specs, its impossible to know for sure, but I’m just looking for an estimate from someone with experience
….. Why are you concerned about a 1 or 2cc difference ? That's likely less than 0.10 change in compression ratio (9.5:1 to 9.6:1) … You could always cc the chambers …..
Normally when heads are milled, only two to three thousands is removed. Nothing to worry about. As Jack mentioned, if concerned, just measure the cc volume.
From: Las Vegas - Just stop perpetuating myths please.
If you want an accurate head chamber measurement you need to use liquid. All you need is 5" X 5" sheet of plexiglass with a hole in it and a graduated cylinder. Windshield washer fluid will work to measure the volume. Anything else and your guessing.
