Looking for a 1996 C4 LT1 cooling system schematic
Old Jul 20, 2019 | 10:07 PM
zindius's Avatar
zindius
Default Looking for a 1996 C4 LT1 cooling system schematic
Looking for a 1996 C4 LT1 cooling system schematic. My cooling fans will not ground and only work when supplied with a direct ground or disconnect the wires going to the temperature sender on the front of the block.
Old Jul 20, 2019 | 11:18 PM
pcolt94's Avatar
pcolt94
If I had to make a guess, when you disconnect the temperature sensor in the water pump, you maybe forcing the PCM into limp home mode. Many things happen in that mode like reduced power, car speed and runs the fans.
Really need the original problem, details, and what exactly you are grounding?
