no start
Old Jul 21, 2019 | 12:23 PM
doityourself's Avatar
doityourself
Default no start
put key in ignition and almost sloppy feel , no dash lites no nothing no spring back, head lite ok, do you think its the key switch or maybe the linkage down steering column ,had all apart 6 months ago and no fun at all ,thankyou
Old Jul 21, 2019 | 01:46 PM
s carter's Avatar
s carter
I know it's not what you want to hear. If you say it feels sloppy your probably on the right track with the switch on the column. But I would also check that the rod is moving all the way to switch. You might also have a broken rack&gear by cylinder
