Fuel Filter Heat Shield
Old Jul 21, 2019 | 02:50 PM
SnorT91Man's Avatar
SnorT91Man
Default Fuel Filter Heat Shield
I found an odd piece of metal in my spare parts box. It's about 4" x 10" and labelled "Fuel Filter Heat Shield," but I sure can't figure out how or where it mounts to the frame. The car is a '91 6-speed. The simple fact it was in my spare parts box leads me to believe I've had this problem before! Suggestions?
Thanks a million!
SnorT91Man
Old Jul 23, 2019 | 04:16 PM
ctmccloskey's Avatar
ctmccloskey
I have never seen one but it makes some sense to have one. Could you please post a picture of this piece?
Old Jul 23, 2019 | 06:15 PM
SJW's Avatar
SJW
I'm not aware of any C4 being delivered with a heat shield on the fuel filter. The in-tank pumps in modern EFI vehicles prevent vapor lock from occurring, so I'd either ash-can that item, or hang onto it if you think it might have been used on some older carbureted vehicle that you still own.
Live well,
SJW
Old Jul 23, 2019 | 07:17 PM
s carter's Avatar
s carter
Way back in C4 History there was a Heat Shield held on with two 10mms head screws.
https://www.ebay.com/itm/C4-Corvette...edirect=mobile
For some reason I seem to remember even further back than 88
Old Jul 23, 2019 | 07:26 PM
WVZR-1's Avatar
WVZR-1
6C -6 in your FSM for an image that shows hardware! Should look like this! If you did the disassembly it should be obvious! Did you get the fuel supply/return lines sorted? The parts SPO shows no better image as to location.
https://www.ebay.com/itm/C4-Corvette...ss!25414!US!-1
Yours should have one also!
Old Jul 23, 2019 | 07:38 PM
SJW's Avatar
SJW
Well, it's a poor day when we don't learn something new. Thanks for educating me. Looks as though this was discontinued after the run of L98 cars? I've never owned one of those.
Live well,
SJW
Old Jul 24, 2019 | 05:45 PM
dm575's Avatar
dm575
I have one on my 91, two bolts that screw up into the frame hold it in place. I know it well because the nuts should be captive in the frame. One of mine came loose, took me a while to cut the bolt so I could change the filter
To Fuel Filter Heat Shield
