Flywheel shim
Old Jul 24, 2019 | 11:08 PM
Maverick1873's Avatar
Maverick1873
Default Flywheel shim
I have an 88, L98 with a 4+3. I currently have the transmission out doing a flywheel, clutch and pressure plate replacement. When I removed the old flywheel I noticed there was a .025 steel shim between the flywheel and crankshaft. I will be installing a new SPEC billet steel flywheel. Do I need to use the shim with the new flywheel or is it something to do with the old flywheel.
thank you for any responses.
Old Jul 24, 2019 | 11:51 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
just did a clutch and flywheel on my 86.
the shim may be from prior resurfacing of the flywheel.
a new one would not require it.
not sure what flywheel unr using but i had a bad sachs flywheel out of the box. it was unbalanced.
