Can’t stop the heat
Old Jul 28, 2019 | 07:33 PM
Anthony Cebada's Avatar
Anthony Cebada
Cruising
Default Can’t stop the heat
I own a 89 c4 corvette...I have replaced & cleaned everything in the cooling system ...yet it’s still running 253 at high speeds ...but at idle it runs 161 ...I’ve heard several different opinions from fuel injectors to retarded timing to bad computer module ...& air in the system ...I need help ...I’m about to give up on this car
Old Jul 28, 2019 | 07:34 PM
Anthony Cebada
Cruising
Somebody please give me a feasible solution...I’ve spent over $2000 on fixing the overheating issue & it’s still overheating
Old Jul 28, 2019 | 07:52 PM
Anthony Cebada
Cruising
I’ve blown a head gasket & just had it replaced...plus replaced the thermostat water pump hose & radiator ...cleaned out the area between the radiator & ac condenser ...I’ve got $2000 in this car in repairs & it’s still running hot ...
Old Jul 29, 2019 | 06:41 PM
Kevova's Avatar
Kevova
Thermostat, wrong water.pump, garbage blocking condenser, garbage between condenser and radiator, radiator tanks filled with crud restricting flow. Heating up at + 40 MPH thermostat, radiator, or airflow thru radiator.
Old Jul 29, 2019 | 10:54 PM
Jitsu's Avatar
Jitsu
Thermostat installed upside down.
Old Jul 30, 2019 | 07:15 AM
Pwnage1337's Avatar
Pwnage1337
Cracked head/block allowing combustion gases into the cooling system. Check antifreeze for combustion gases
Old Jul 30, 2019 | 07:17 AM
ex-x-fire's Avatar
ex-x-fire
Take a picture of the front of the car, around the air dam area.
Old Aug 1, 2019 | 02:57 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Sure sounds like a radiator air flow issue.
Since it happens at hi-speed, check air damn area for damage.
Old Aug 1, 2019 | 08:16 AM
Randy M's Avatar
Randy M
I would check the water pump. I have heard of the impellers coming loose from the shaft. Make sure you have good flow.
Old Aug 1, 2019 | 10:36 AM
pcolt94's Avatar
pcolt94
This is a possibility and should be checked out.
Ok so it sounds like you have done all the right things replacing the major components.
To see if the water pump is basically working, when the engine is cold, remove the radiator cap. Then look in as rev the engine slightly. You should see some flow of coolant. If it's completely still might be a flow problem. When it comes up to temperature, see if both radiator hoses are about equally hot.
Old Aug 1, 2019 | 11:10 AM
vader86's Avatar
vader86
Something is wrong with the water flow, in that its not flowing.
Stock thermostat should open at 195F, if you don't see the temps pause at that temp and hover around it, then its stuck.
Verify fans are operating main fan at 228, any pusher in front about 10F higher.
Open the rad cap at startup and verify that coolant is flowing once the t-stat is open. You'll definitely see it. Pull the throttle back once it starts bubbling out of the cap and that will suck it down, you'll see the flow. That will at least tell you whether the WP is moving anything or that there is a blockage.
If its only happening at speed, then there is an airflow issue over the radiator, something is blocking that. C4s get hot at idle but at speed the temps should drop into the 200-215 range.
Old Aug 1, 2019 | 11:18 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
clogged cat
Old Aug 1, 2019 | 11:28 PM
BLUE1972's Avatar
BLUE1972
collapsed lower radiator hose, common problem
go with a 160 stat.
Clogged radiator, lower sections are full of leak stop. - have it boiled.
Wrong fan and it's running backwards. Not blowing air through the rad toward the motor.
Missing front air dam.
Old Aug 1, 2019 | 11:40 PM
vader86's Avatar
vader86
Originally Posted by VikingTrad3r
clogged cat
Would show up easily at night, pop the hood and see if the manifolds are glowing red. Otherwise would show as a severe drop in power if you had it clogged up enough to create this much heat in the engine.
To Can’t stop the heat
