'84 Oil Pressure
Old Jul 30, 2019 | 04:47 PM
James C4's Avatar
James C4
Default '84 Oil Pressure
I just had the oil pan resealed on my '84 and the oil pressure is now lower than it used to be. The shop said I'll need to add another half quart of oil because the 5 quarts I had wasn't enough but that shouldn't cause my oil pressure to be so low since the car used to leak it like crazy. Driving normally it hangs around the mid 40's with 5w-30 oil and 18 at idle. The problem is when I accelerate or turn hard, especially to the left, it drops. At one point I turned left from a stop sign and it dropped to zero. I had 10w-30 in the car before and it would idle at 20-25 psi and about 50 when I was just cruising down the highway. Obviously the the 5w-30 will have a bit lower pressure than 10w-30 because it's thinner and I just went with it because the car will probably sit a lot until I'm home for Thanksgiving and Christmas break but the weight of the oil shouldn't drop my pressure that much. Any tips would be greatly appreciated.
Old Jul 30, 2019 | 04:54 PM
s carter's Avatar
s carter
You say the pan has been off Recently and now pressure is lower now. Did you put another Pan on, or was it a Pull and seal up. Because it sounds like your pickup is not in the bottom of pan, especially when you say you 0 out on turns.
Old Jul 30, 2019 | 04:57 PM
James C4's Avatar
James C4
@s carter they took the old pan off and put it back on. I'm thinking it could be the pickup but I've never had the oil pan off so I don't really know what's going on down there. I called them and they said to drive it after adding that other half court and if it's still messing up to bring it back.
Old Jul 30, 2019 | 05:16 PM
s carter's Avatar
s carter
ok so we have the original pan so the pressure should not really change. When reinstalling pan it can be a challenge to get the Pickup inside the Wind age tray and the pickup can be easily knocked up in frustration. So I would get the car up in the air drain the oil and use a wire Camera and view the pickup make sure its toward the bottom.or put a Mechanical Pressure gauge to get a Direct Reading.
Old Jul 30, 2019 | 05:20 PM
James C4's Avatar
James C4
@s carter okay. Thanks for the info. I'll check it out and update the thread.
Old Jul 30, 2019 | 05:26 PM
s carter's Avatar
s carter
Do it sooner than Later if you truly are sucking air NOT GOOD
Old Jul 30, 2019 | 08:46 PM
James C4's Avatar
James C4
@s carter I went to add the extra half quart of oil and realized my dipstick wouldn't go in all the way. It sounds and feels like it's hitting something. I'm guessing that could be the oil pick up you mentioned being loose in the bottom of the oil pan. The car is going back to the shop tomorrow so hopefully they'll get it right this time.
Old Jul 30, 2019 | 09:03 PM
s carter's Avatar
s carter
Watch the pressure if it drops to uncomfortable level. get a Tow it's not worth wiping out a good Motor.
Old Jul 30, 2019 | 09:06 PM
James C4's Avatar
James C4
@s carter it only got dangerously low if I really pushed it through a corner or accelerated hard. Other than that it was at least holding 35 so I should be fine if I just drive slow unless 35 is unacceptable.
Old Jul 31, 2019 | 12:59 AM
Hot Rod Roy's Avatar
Hot Rod Roy
The oil pick-up tube presses into the oil pump, so it sounds like they knocked the oil pick-up tube out of place when they replaced the pan. Get a picture of the inside of that pan while they've got it apart. I was surprised how complex the baffles are when I had my '84 apart, but I didn't get any pictures. Those baffles may have baffled the mechanic! Doing this work with the engine in the car would be a challenge!
A question for the experts (which I'm not): Is the '84 oil pan a one-year only part?
Old Jul 31, 2019 | 02:29 AM
zachaeous's Avatar
zachaeous
When I built an engine for my 84 using the original block, I had to find a different oil pan due to damage on the bottom of the original pan. The 84 and 85 had the same oil pans with the dipstick on the passenger side. It was hard to find one that was not mashed up on the bottom. In 1986 GM went to the one piece rear main seal and of course the pans were different. Part number for the 84-85 pan is 14082350.
Old Jul 31, 2019 | 05:45 AM
84 4+3's Avatar
84 4+3
I don't recall the inside of my pan being that intricate if I could be honest...
Old Aug 1, 2019 | 09:33 AM
James C4's Avatar
James C4
The mechanic said the sump, which I'm guessing is the pick up, at the bottom of the pan had been knocked up when they installed it. They reinstalled it correctly and my oil pressure is back up to exactly what it should be. Hopefully the engine wasn't damaged.
Old Aug 1, 2019 | 09:39 AM
84 4+3's Avatar
84 4+3
Run it for a bit, change the oil and cut open the filter. Look for metal. If its clean you're fine.
Old Aug 1, 2019 | 11:05 AM
s carter's Avatar
s carter
Well done, I'm glad it has been fixed before any Known problems. as 84 4+3 said run it and check. Do to the fact of you where on top of the Problem you should be ok and the check filter in a 100 miles or so is more of a Put Mind at Ease.
To '84 Oil Pressure
