where to get new crank shaft hub
1996 c4 lt1 i think its 12550097 part#.genuine gm parts states discontinued in 09.cant find by part # on line.summit racing will sell you anything just for a sale.please no more head aches .i do just fine on my own.should i buy harmonic balancer for balance.thanks.
Pro Mechanic
Welcome to the forums!
If I were buying, I'd got right to the classifieds section of this forum, and find one of the many "part outs". I'd find one that is a '-92-'96 car and I'd message the seller about the hub/damper. If that didn't work, I'd look on eBay.
I bet you could find a good used hub in less than 20 minutes of looking.
Pro Mechanic
damper and hub should be the same, 'Vette or F-body. Shouldn't matter. 4 tooth crank wheel is not part of the hub.
Pro Mechanic
No? Different p/n?
The hub is the same.... the damper/pulley is different between F body and Y body LTX engines.
96 is a 1 year specific part for the Y body hub. Same hub was used in 96 and 97 in the F body. Its shorter to accommodate the crank position reluctor ring.
Will
Will
Tom400CFI (08-06-2019)
Pro Mechanic
Damn...that is some good quality info right there.
If you cannot find a GM factory hub, you can buy a new aftermarket billet hub. It's made by Pioneer/Power Bond for Jegs.
https://www.jegs.com/i/JEGS/555/51609/10002/-1
You can also buy a new damper/pulley. It's a stock replacement part made by Dorman. FYI Pioneer/Power Bond does not mfgr the correct damper/pulley for the Y body and this Dorman is the only option except a real racing damper and hub assembly from ATI.
https://www.jegs.com/i/Dorman-Produc...4-107/10002/-1
I have used these many times on LTX builds where the customer did not have the $$$ for the ATI damper. These 2 parts work together and the stock damper/pulley also fits on the billet hub. For the Corvette Y body, you will need to remove the roll pin in the billet hub with the Dorman and factory damper/pulley but the last hub I used (2 months ago) didn't even have the roll pin.
I hope this gives you guys some options on fixing these older LTX engines.
Will
Will
