dash removal
Old Aug 11, 2019 | 02:31 PM
doityourself's Avatar
doityourself
Default dash removal
1996 C4 ,I've got short [wire melted] from turn signal connector[bottom steering column] wire disappears behind right side gages with 100 other wires ,I think its the ground that goes under ignition switch bolt ,anyway I'm trying to get upper dash pad off to fallow melted wire and replace and fix horn that don't work and a/c vents that only blow out defrost vents , do you have any sites to show dash removal ,I got drivers side loose all screw out I think but passenger side I cant find any. thank you
