Throttle Coolant Bypass
Old Aug 18, 2019 | 05:22 PM
Charsel's Avatar
Charsel
Default Throttle Coolant Bypass
Just completed TB by-pass. All hoses were 3/8", so anyone need a 3/8" to 5/8" brass hose adapter? No way 5/8" hose was needed, just connected Lft side hose to heater hose line; all 3/8" fittings. Maybe needed for F Body No leaks, so time for swim and adult beverage
LT1 Throttle Body Coolant Bypass
By IBxAnders - April 21, 2010
0 COMMENTS
One of the most effective
ways to cool your intake charge is to bypass the 180+ degree coolant
flowing through your LT1 throttle body. The current purpose for the
coolant flowing through the throttle body is to prevent it from freezing
under extremely cold temperatures. This is great to keep if you park your
LT1 outside in Minnesota, but let\’s be real. Most Corvette driver\’s
live in FL or CA and never even drive them in the rain, let alone
snowy/freezing conditions.
First things first. You can buy
this same kit from XYZ Corvette Performance Shop for $19.95 + Shipping and
Handling. Or you can go to your local hardware store and spend less than
$8! Either way, you still have to do it yourself if you buy the parts,
unless you pay a mechanic $65 an hour. Save your $$$$ and do it yourself
and buy the following three items:
1. Brass 3/8\” to 5/8\”
hose adapter
2. 1.5 feet of 5/8\” hose
3. (2) small diameter hose
clamps.
Now the installation procedure. Make sure the engine is
cold! Then, on the passenger side locate the furthest hose to the lower
left on the right side of throttle body. Remove the hose from the throttle
body. There will be a large amount of coolant spilled so be prepared. Then
remove the other side of the hose. Not hard yet, right? Right. Then
install the 1.5 feet of 5/8\” hose you bought to the side you just
removed and attach the brass fitting to the side that is open. Clamp the
hose to the brass fitting and then go to the driver\’s side of the car.
On the driver\’s side, locate the lowest hose going into the left side
of the throttle body. Now, remove that hose and attach it to your 3/8\”
side of the brass fitting. Clamp the hose down to the fitting and bingo!
The line has been bypassed. Now add about 4 cups of a 50/50 mix of water
and antifreeze and wallah you are done. Start the car and feel the top of
the throttle body. Nice and cold, unlike before you started this 30 minute
procedure.
Now, you say. What is this all worth in the long
run? How many 10th\’s will this take off in the 1/4 mile? I can\’t
say, but you have to remember that combinations of performance
modifications will get you that winning combination. So, this I can
guarantee is a start to a key combination.
Old Aug 19, 2019 | 08:46 AM
90zz41's Avatar
90zz41
7th Gear
so the tb stays a lot cooler?
Old Aug 19, 2019 | 06:55 PM
Charsel's Avatar
Charsel
Yup. Now, on to headers.
Old Aug 21, 2019 | 11:51 AM
aklim's Avatar
aklim
Sure but what is the net effect? The imaginary effect is your car zips another second faster. I have real doubts it will do much, if anything for a street vehicle besides unclutter the system so you can have easier access. Bottom line, if you are looking for gains besides easier access, that lies in the realm of the SOTP dyno.
Old Aug 21, 2019 | 05:22 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Not much gain with that mod!
Old Aug 21, 2019 | 06:20 PM
aklim's Avatar
aklim
Only gain is you can remove the intake easily with no coolant spill so I'd like to do it with a flush
Old Aug 21, 2019 | 07:07 PM
Charsel's Avatar
Charsel
Did it knock .5 sec and add 5 mph to 1/4 mile? No. But part of little steps to help breathe. Next step headers, then cam, then tune. Heads ported when budget fits.
Besides, what else to do in FL when raining???
Old Aug 21, 2019 | 08:01 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
One less coolant line to worry about plus I don't think TB icing will ever be an issue in Fla.
Old Aug 21, 2019 | 09:05 PM
Charsel's Avatar
Charsel
No sir
To Throttle Coolant Bypass
