Which Tranny Cooler Line is Which?
Old Nov 11, 2002 | 05:42 AM
Joeyvette's Avatar
Joeyvette
Default Which Tranny Cooler Line is Which?
I have a 94 coupe with an A4 that I'm putting in the B&M tranny cooler. Which line is the return to radiator and which is the return to the tranny. Thanks for the help.
Old Nov 11, 2002 | 08:34 AM
AJR's Avatar
AJR
Default Re: Which Tranny Cooler Line is Which? (Joeyvette)
On my '95 the top line to the radiator is from the trans. You can test by running the car for 10-15 minutes and putting your finger on the lines. The line from the trans to the radiator cooler should be noticably warmer to the touch.
Old Nov 12, 2002 | 04:15 AM
Joeyvette's Avatar
Joeyvette
Thanks. I'll install the cooler this week, I'm currently getting a new water pump, opti, and intake gasket installed under my extended warranty. :cheers:
To Which Tranny Cooler Line is Which?
