Need help for 1985 C4
Old Aug 21, 2019 | 12:16 PM
Larry Hargrove's Avatar
Larry Hargrove
Default Need help for 1985 C4
Someone help me please. My '85 has a problem. It will idle just fine but when I try to accelerate it coughs, sputters and backfires. If I stay on the throttle it will catch up and run good. It is worse under load. Anybody have a solution for this problem? What should I be looking at? TIA
Old Aug 21, 2019 | 12:44 PM
knikula's Avatar
knikula
I'd verify correct fuel pressure first, then check the TPS ... throttle position sensor.
Old Aug 21, 2019 | 01:17 PM
vader86's Avatar
vader86
First thing is pull the codes, if its acting up that bad there should be one set. Check FP at the rail at idle and with your hand on the throttle linkage, then watch with the engine turned off. TPS voltage too. Note most recent fuel MPG
Old Aug 22, 2019 | 10:45 AM
Larry Hargrove
Ok. I was doing some checks that you guys suggested this morning and got some mixed and one unexpected results. First I could not get a voltage readings on any of the three wires going to the tps except the bottom one and it was giving a varying reading of .10 - .40 volts. Here is the unexpected part. I started the engine and then I realized that I had not reconnected the plug to the tps.and it was running the same as it does with the wires connected. Is this normal?
Old Aug 22, 2019 | 10:59 AM
PacerX's Avatar
PacerX
Voltage check is between the two upper pins. I twisted up a little braided copper wire and inserted it into the pin cavities to do mine.
With no TPS plugged in you should set code 22. Did it?
Pull. The. Codes.
Old Aug 22, 2019 | 11:23 AM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
Pull. The. Codes.
With. A. Paperclip.
google that and u will see how.
Old Aug 22, 2019 | 11:52 AM
xrav22's Avatar
xrav22
Put 1 small pin in the top two tps wires and turn the key on(no start) and the reading should be .54. The key is that when you turn the throttle it should climb smooth to 4. something.
Then put the paperclip in the top right 2 ports in the obd connector(a and b) then you will see code 12 one blink then 2 blinks, after that you will see any codes you have.
Good Luck!
To Need help for 1985 C4
