Engine idle misfire
Old Aug 24, 2019 | 03:14 PM
rford's Avatar
rford
1st Gear
Default Engine idle misfire
1995 corvette 350/auto 80K miles very well maintained that has developed a periodic miss at idol. My mechanic is having a problem with this issue. Car runs strong otherwise.
Any ideas or suggestions? Thanks Richard.
Old Aug 26, 2019 | 09:42 AM
bjankuski's Avatar
bjankuski
Check the cap and rotor on the OPTI spark for corrosion, also check the fuel injectors. An idle miss that cleans up with some throttle or RPM for some strange reason can be a bad cap and rotor. It could also be a bad injector that does not deliver fuel at idle. I assume he checked the basics like plugs and wires.
