89’ code 36
Old Aug 24, 2019 | 10:17 PM
Karen S. Frederick's Avatar
Karen S. Frederick
1st Gear
Default 89’ code 36
Trying to figure out what is causing this code 36 to keep coming back, replaced the mass airflow sensor, replaced O2 sensor after about 100 miles the code comes back
Old Nov 5, 2019 | 07:08 AM
thomas o'connor's Avatar
thomas o'connor
Default Code36
Hello Karen
I to own an 89” and have been experiencing the same problem and I’d like to let you in on a couple of things.
#1 As I found out the hard way 88 & 89 did not use a A/C Delco MAF sensor.. They came through with a Bosch sensor part # Repc316708 available on eBay from Carpartswholesale.. Any other sensor will not work properly in our cars.. To check the sensor with the engine running at normal temp carefully unplug the sensor and the engine should die.. If the engine keeps running the sensor is no good.. If the engine dies it tells you the MAF sensor and relays are working..
#2. Code36 can also mean you have a vacuum leak as well.. As with my car I have only 23k on it yet almost every vacuum line needed to be changed due to age.. If you grab any of the lines and get a black greasy film on your fingers it’s time to change them..You’ll need to check them all from front to rear especially to the fuel tank.. One almost always overlooked is just in front of the left rear tire about 2 1/2” long that goes from vertical to horizontal.. The other is hidden up inside the spare tire compartment about 6” long.. The small one is 3/16” diameter and the long one is 1/4” dia..
In my 89” I’ve changed all the vacuum lines the MAF sensor and relays the TPS and the IAC value.. When I disconnect the battery and clear the codes the car runs perfectly but after running 50 miles or so then shutting it off the code comes back on and the car starts running shitty again.. I also noticed I’m not getting any vacuum to the fuel tank when I unscrew the cap.. Needless to say I’m still looking for the problem..
oh well the joys of owning a C4 I guess.. If and when I figure it out I’ll get back to you but I hope this will help you out in the meantime..
Best of luck
Thomas
Old Nov 5, 2019 | 08:28 AM
28uniflite's Avatar
28uniflite
Code 36 has to do with a fault in the MAF burnoff feature. When you shut down the car, a relay sends voltage to the MAF for a few seconds to heat up the sensor wire and burn off any contaminants.
There are two relays on the firewall directly behind the battery. One controls general power to the MAF, the other controls the burnoff feature at shutdown.
I recently had code 36 come up on my '89, and traced it to a bad burnoff relay. $15 later I'm up and running with no codes.
Old Nov 5, 2019 | 09:08 AM
BlowerWorks's Avatar
BlowerWorks
Supporting Vendor
You can do away with all the BURNoff crap if you use a modern MAF sensor. See my website: BlowerWorks.net
Old Nov 5, 2019 | 12:14 PM
Tunedport90's Avatar
Tunedport90
You can have it tuned out
www.tunedperformance.org
To 89’ code 36
