Car won't start!!!!!!!!!
Old Nov 11, 2002 | 08:19 PM
BAdAzZV8's Avatar
BAdAzZV8
Default Car won't start!!!!!!!!!
OK, I changed the opti, and now the car won't start. I took the little shaft out of the old optin and put it into the timing gear, then put the opti on. Then I put the harmonic balancer back on, then the waterpump assembly, then the other minor details. I am wondering what is wrong. I can see a spark on the coil when I try to turn it over. It turns over, but won't start.
The only thing that I can think of is, when I put the shaft into the timing gear, I put it in too tight(I nudged it in with a tap from a rubber mallet). And that the opti gear isn't catching.
Any help would be great.
Old Nov 11, 2002 | 10:17 PM
aroulette's Avatar
aroulette
Default Re: Car won't start!!!!!!!!! (BAdAzZV8)
check loose connectors to dist cap. Also could be ICM and pickup coil
