I want a Corsa system for my '95. Granted, like the look of OEM style LT1 tips, but maybe the Corsa Pro Series tips will grow on me. Anyhow, I want the system for the value, sound, and slight power increase. Here's my question: I want the Corsa sooner, and I want headers later. If I put on a Corsa catback as is from the stock cats back, can a shop later on get the installed Corsa system to fit a set of long tube headers with random bullet cats or other after market high flow cats? Cats will be a necessity, won't run the car without them. Reason I don't do headers and catback at same time: the catback won't give GMPP any excuses to try and bail on any possible future unforeseen repairs, whereas a set of headers might make GMPP uncomfortable enough to bail on me on some possible repair. GMPP is good until August 2003 on my car.
Still wish LT1 tips could be fitted to the Corsas :nopity
Re: Corsa Power Pulse catback system question (Lone Ranger)
those tips are an integral part of the system.
the inner tips do most of the hard work, and the outer tips are for pressure release associated with the entire power pulse concept. rather neat, really.
I would suspect that yes, what you want to do can be done. it falls under the catagory of "any thing can be done given your ability to weld".
the cat pipes are seperate, so if you add long tubes and cats right off the collectors, then yes, you can link up the corsa to the cats.
I loved my Corsas, the only gripe about them is the fact the outside tips never get dirty, it makes them almost seem fake! I hear people saying they flow under hard throttle but I've drove the car hard enough to get them flowing but never had any soot on them. I have the B&B 3 inch now and I love it. much louder and both sets of tips are dirty!!!! More time I can spend cleaning!!!!!!!! Yeah!!!!!!!! :reddevil
The tips themselves are not an integral part of the system...it's the muffler. You can have the individual tips cut off after they exit the muffler then have a shop weld up an LT style tip and there would be no difference other than the look.
Re: Corsa Power Pulse catback system question (Zix)
I did not know this either. I grow confused now. Must smoke the peace pipe and reflect upon this.
I'll confuse you more, you need both tips. The outer tips are what flow when the car is at cruise or idle, the inner tips flow at cruise and idle, but at WOT, the inner tips will flow more. There is a diagram that comes with the system that explains how it works, obviously not everyone that has the Corsa has read the paperwork that comes with it.
I know for C5, the Corsa system is an approved by GM, so that shouldn't affect any type of warranty work.
Also if you were to put headers with th estock exhaust, you'd be in the same boat, since the Corsa replaces the stock system exactly.
Re: Corsa Power Pulse catback system question (Mr Mojo)
One named Mojo seem to know truth. No more forked tongue. Tonto tell Masked One "keep Pro Series tips" when gettum Corsas. Put peace pipe back in teepee. Masked One will be proud of Tonto for seeking truth for him.
Re: Corsa Power Pulse catback system question (bogus)
This is true, but this is dictated by the design within the muffler...has nothing to do with the exterior tips themselves. If you cut off the Pro tips that come with the exhaust and weld up an LT look-a-like tip they will still function 100% as normal, you just would not notice the difference in flow from the individual tips anymore. This has been done a few times by an exhaust shop here locally...not to mine because personaly I like the individual tips that come with the corsas. You do not NEED both tips...as long as you do not modify the muffler canister, you will be fine.
