messed up alignment after doing axle work???????????????????
Old Nov 11, 2002 | 09:50 PM
DarkoStoj's Avatar
DarkoStoj
Default messed up alignment after doing axle work???????????????????
ok i changed my rear passenger side axle, hub/bearing, dog arms, and that thing the hub bolts into. I had the car jacked up for a while pretty high, when i took it out for a drive the steering wheel was off about 2" to the left. I don't understand how this happened since i didn't even touch the front!! anyone have any help here? i buy :cheers: for whoever helps me :cool:
Old Nov 11, 2002 | 10:18 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default Re: messed up alignment after doing axle work??????????????????? (DarkoStoj)
Go get an alignment.... Not sure what all to removed and or replaced but yes the rear does effect the front. It is now tryin to compensate for the rear...
Old Nov 11, 2002 | 10:26 PM
DarkoStoj's Avatar
DarkoStoj
Default Re: messed up alignment after doing axle work??????????????????? (fsr402)
it drove straight before i changed everything, i could take the wheel and move it up and down atleast 4", how does putting in a good hub mess it up? could i maybe adjust the toe in-toe out on the rear passenger wheel since that is what i changed?
Old Nov 12, 2002 | 08:25 AM
PTz-92-LT1's Avatar
PTz-92-LT1
Get an alignment. I do mine every year....$50 is a cheap investment fortire longevity, handling and my life.
Old Nov 12, 2002 | 06:08 PM
No Go's Avatar
No Go
The lower spindle rod goes from the the outside of the car (at the hub) to the inside of the car (to the differential). At the differential is a eccentric for that wheels camber...which if disturbed will change the camber and the toe of that wheel. So along with your new parts correcting the sloppy suspension, you may have tweaked the original alignment too.
Get an alignment.
Old Nov 12, 2002 | 11:21 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Antime you mess with anything pertaining to the springs....height...tires...
even tire change....check it out...realighen..(spell)..
Ok...
:cool:
Old Nov 13, 2002 | 09:55 PM
h rocks's Avatar
h rocks
You changed the toe for sure, and likely the camber as well.
Get an alignment.
To messed up alignment after doing axle work???????????????????
