Does anyone lube 6-speed shifter?
Old Nov 12, 2002 | 03:46 AM
merrick's Avatar
merrick
Default Does anyone lube 6-speed shifter?
The manual mentions it, but doesn't give any details. I noticed a little sqeak going to first gear.
Old Nov 12, 2002 | 07:00 AM
CowboyNVette's Avatar
CowboyNVette
Default Re: Does anyone lube 6-speed shifter? (merrick)
Not yet but I didn't know I had too...I never read the instruction manuals on anything though.. :smash:
Old Nov 13, 2002 | 03:17 AM
merrick's Avatar
merrick
It is in the front of the manual under lubricant specifications, but no details.
[Modified by merrick, 3:18 AM 11/13/2002]
Old Nov 13, 2002 | 03:23 AM
SharkB4C4's Avatar
SharkB4C4
Huh? The shifter on ZF6 is internal, so I always assumed it doesn't need lubrication. I may be wrong.
If the manual you're looking in is Haynes or Chilton, perhaps it's referring to the shifters for the 84-88 4+3 trannies ... those were external, so required lubrication. It was easy on my 88--I took the carpeted panel off from the left side of the transmission tunnel to get at the shifter mechanism, and just sqirted engine oil.
Old Nov 13, 2002 | 10:52 AM
Mr. G.'s Avatar
Mr. G.
White Lithium Grease.
Now getting to the shifter pivot points is another story, but I'll give you an alternative.
To do it right, you'll need to remove the console including leather boot. Under the console is a rubber boot with 4 acorn nuts. Remove the 4 nuts, and slide the rubber boot up the shifter. (the boot is larger than the cut out in the floor) This will give you a clear view of the shifter pivot points.
An alternative is to buy a SPRAY CAN of white lithium grease. Using the extention that comes with it, slide the extention between the shifter and leather boot, and continue down through the rubber boot and spray.
You may need to cut a hanger and tape it to the extention to make it rigid enough to pass between the rubber boot and shifter as it's a tight fit.
While the shifter is attached to the top of the trans, it is fully enclosed in a rubber boot, and is not part of the trans internals as some believe.
Hope this helps,
Joe
To Does anyone lube 6-speed shifter?
