Headlight problem 1992 Corvette
Old Sep 2, 2019 | 10:01 PM
mreksc's Avatar
mreksc
Navigator
Default Headlight problem 1992 Corvette
My headlights work fine as long as fog lights are off. If I turn on the fog lights, the headlights automatically go onto high beam and will not dim down to low beam. Any ideas what the problem is would be great.
Old Sep 3, 2019 | 01:09 PM
pcolt94's Avatar
pcolt94
Such a strange problem. In reviewing the circuits for my 94, they are probably very close. This is definitely a strange circuit as how the design is for the dimmer switch and fog relay.
There is a diode in the headlight switch that feeds the fog light relay. The other end of the relay coil goes back to the high beam headlight. If the diode shorted it might me doing something strange like supplying power to the high beam headlight. As you change to low beam you might not be able to "see" the difference in light. (Possibly bad headlight switch).
You say the hi-low headlight switch is basically working so that sounds OK
The fog lights work so it seems the fog light relay is working.
The difference in the 92 vs. the 94 is the ECM and PCM. It is part of the hi-beam indicator control. Don’t know if that could be a factor or not, but not really related to fog lights.
This is all opinion based on my book. I can't really nail down the problem without making my own measurements so it's the best I can do for now, take it with a grain of salt
Old Sep 4, 2019 | 01:02 AM
aklim's Avatar
aklim
Do you possibly have LED bulbs?
Old Sep 5, 2019 | 01:24 AM
mreksc's Avatar
mreksc
Navigator
Yes I have LED bulbs, but it did the same thing with the stock bulbs.
Old Sep 5, 2019 | 01:46 AM
mreksc's Avatar
mreksc
Navigator
I have replaced the headlight/fog light switch assembly. No change in problem.
Old Sep 5, 2019 | 02:55 PM
pcolt94's Avatar
pcolt94
Until I get a great idea the only things that comes to mind is a open or poor ground.
Hard to say where to exactly look for it.
Have you had any part of the car apart or done work on it before the problem occurred?
Old Sep 7, 2019 | 01:20 AM
mreksc's Avatar
mreksc
Navigator
No. Have had this problem since I got the car earlier this year. Talk to the guy I bought it from and he said he never had a problem with the lights.
To Headlight problem 1992 Corvette
