Yes I searched, but a lot of info is still old. What is the consensus on wheel bearings now? 10 years ago when I was racing more often I found the $40 ebay bearings lasted just as long as the $300 Timken. My car sat for years and I got it out to play more than once this year and now I need new bearings again. Is it still eBay chinese cheapies, or is there something that lasts a little longer now? I am eyeballing the Strano kit for the SKF C5/6 bearings on the front, but still no new developments on the rear?? There was a company that was selling the rebuildable front hubs for Camaros, are they no longer in business?
C4 of Year Winner (appearance mods) 2019
I put Timkens on my 89 6-7 years ago and they are still fine. Of course, I don't have a track car -- which means they don't see the same side-loading. Also, I bought them for all four corners for about $100 each....not $300 each. Rock Auto still sells them in the same price range.
FWIW, I have had several Timken bearings fail prematurely (~25-50k)over the last few years. While these failures were not in a Corvette, I have started using SKF bearings with better results.
I don't see any SKF for the rear. Got a part number?
This was a long time ago I priced good bearings, but I remember them being in the $800-1000 range for a set of name brand. I see they are much cheaper on Rock Auto now. If they can last me 2-3 events I'd be happy.
I had a rear hub start to fail after getting my 86. I got a set of Centric hub to use and use it I did. I've had Centric hubs on my truck for over 70K and they're still running strong. My car is street only, and it's worked fine so far.
On Teflon washers, check out IIRC Corvette Central. They have reproductions and AFAIK are the only place you can get any. IMO any time you tear the rearend apart, replace the Teflon washers at the same time if you can. If not, grease the heck out them.
I had a set on the rear of my 90 for about 55,000 miles that I paid about $100.00 for both rear. I just replaced them with moogs that have a 3 year warranty from rockauto about $80.00 each.
The better grade rear hubs that I bought for my '96 from Napa are SKF's. Says so right in the box even though the box says NAPA. Check them and see if they have them for your year car and if those are SKF's unfortunately they are 200'ish. I forget what I paid.
SKFBR930024 That is the PN for my 89, I am not sure if it applies to other years.
I think anything new for front or rear direct replacement will be made in China now, regardless of the brand on the box. Some claim that SKF or Timken are made in China in a different factory and to a better spec than the cheapies. I really have no way of knowing if that's true or not, although I know it certainly could be true (i.e., China can make good parts if they are held to a high standard by the contractor). The Strano kit will be a good option for the front if you plan to keep tracking the car. It's probably worth it for that use. For just autocross and street, I'd probably save the money and try to buy new replacements that don't have play out of the box. The fronts are just so easy to change. There is no solution for the rears that I know of.
Thanks guys! I know the race bearings for C5 and C6 are made by SKF and they last a lot longer. Hoping the SKF rear might last a little bit longer as well for our cars. This car is track only and doesn't see any street miles. All miles are HARD on track.
The race-oriented X-Tracker hubs from SKF are the ones that require the Strano kit to adapt to a C4. I know you know this, Kubs - I'm just clarifying for others that are reading this. I don't think the regular stock-replacement SKF hubs are made in the US anymore, whether they are for the C4 or F-body.
I appreciate the link for the washers also!
FWIW, you probably need to plan for a lead time of 1-2 months after you order those. They seem to take that long to get them to you. I don't know if that means someone is making them on a per-order basis, or what. But the good news is that they will get to you.
As you mentioned before, they probably are all made in China. Im just hoping that the SKF brand would accept a little better quality coming out than some of the others, considering their reputation with the race hubs.
Good to know! I have all winter to work on it but it sounds like ill need to get my order in soon!
As far as the washers, what makes them special other than the teflon coating? Wouldn't a regular flat washer of similar size work? Im not concerned with noise on a track car, as long as it performs the same job.
The Hub bearings I got from Moog say made in the USA so I am assuming they are but then I thought all there stuff was made in china .
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Yes I thought that was pretty good for cheep china bearings, the ones from Moog should last longer if you look at SKF they have a 36 month / 45000 mile warranty.
Don't they form fit when everything is tightened up ? The ones I have are not flat. Of course I put them
up for safe keeping, tomorrow or so I will see if I can figure out where I stuck them and get a picture.
If you look at the one on CC, you can see the flange on the ID.
