EGR Valve leaking?
Old Nov 12, 2002 | 02:39 PM
корвет's Avatar
корвет
Default EGR Valve leaking?
I've had a slightly rough idle for awhile. I now get code 32. I took the egr valve off and the diaphram appears to work well. However, when the valve is closed, it does not seal completely. Should it?
Can I take it apart to clean it? What the best method to clean? I suspect carbon build up.
Old Nov 12, 2002 | 03:02 PM
ittlfly's Avatar
ittlfly
Default Re: EGR Valve leaking? (cOvette)
Connect a vacuum guage to the EGR. If it hold 10"hg for 20 sec. the valve should be ok.
Old Nov 12, 2002 | 03:48 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The EGR should seal so that no exhaust gas flows, otherwise the EGR Temp. Switch atop the EGR tube will close and the ECM will throw a code.
I've not cleaned one, only replaced it. You could try carb cleaner.
I have a method on my site to test the EGR system components.
Old Nov 12, 2002 | 05:26 PM
Lone Ranger's Avatar
Lone Ranger
I used throttle body cleaner and q-tips to clean mine, until the tb cleaner would pool in the cavity w/the valve's pintle closed, with negligible leak down thus indicating the pintle was sealing pretty well. A new one is about $44 from Jeff Kopp @ 1-800-728-8267 (Superior Chevrolet)
[Modified by Lone Ranger, 4:27 PM 11/12/2002]
Old Nov 13, 2002 | 07:13 PM
корвет's Avatar
корвет
Default Re: EGR Valve leaking? (Lone Ranger)
Well, for reference it will come appart. I clamped the round thing surrounding the pintle and screwed it out. It is now soaking in Carb cleaner.
I'll save that $44-$70 yet!
Old Nov 14, 2002 | 04:37 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
The manual specifically says not to expose the diaphragm to harsh solvents. Oh well, this is how I cleaned mine, despite reading that. $70 seems like a steep price to pay for a stupid little valve.
To EGR Valve leaking?
