Aftermarket EFI computer
Old Sep 9, 2019 | 07:51 AM
81C3Corvette's Avatar
81C3Corvette
Cruising
Default Aftermarket EFI computer
Has anyone done a heart transplant from a 95 C4 (LT-1) into an 81 C3? What EFI computer did you use?
Old Sep 9, 2019 | 09:55 AM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
The issue you will face will be the OptiSpark distributor. If you are not going to try and adapt the oem one, then one of the best replacements for this is a bit pricey. Why are you looking at an LT1 -vs- a std configuration SBC ?
https://www.eficonnection.com/home/c...efi-24x-lt1lt4
Old Sep 9, 2019 | 11:53 AM
dizwiz24's Avatar
dizwiz24
Holley makes a really sweet, user friendly engine management system.
that is what id go to in this situation
Old Sep 9, 2019 | 05:11 PM
James93LT1's Avatar
James93LT1
Veteran: National Guard
You can run the stock 94-95 Corvette/ Camaro LT1 PCM.
https://howellefi.com/product-catego...-lt1-products/
Old Sep 10, 2019 | 01:26 AM
drcook's Avatar
drcook
Here is how to do it using an existing wiring harness. Click on engine conversions. The article discusses how to do using a Camaro harness, but if you have the donor 95 Corvette (not just the motor) the harness/ECM/sensors will be the key to the swap.
https://www.vetteworksonline.com/index.html
you can do it, but if you use the oem ECM you will deal with the programming issues that are inherent to the Gen2 family of ECM's. There is broader tuning support for the later GM ECM's. Having a stock harness and ECM, (especially if in hand already) keeps the cost down. Having to go new (whether using the stock ECM or EFI Connection's conversions) is going to cost.
Old Sep 10, 2019 | 08:41 AM
C409's Avatar
C409
….. Many Moons ago , I put an a '93 F-body LT1 and trans into a '74 … I had the entire donor car and used the harness and ECM from it to run the works in the shark car … it was a very sweet combo .....
To Aftermarket EFI computer
