Compression Ratio vs Octane Table?
Old Nov 12, 2002 | 04:01 PM
lead_foot's Avatar
lead_foot
Default Compression Ratio vs Octane Table?
Anyone know of a table or calculation that shows the maximum compression that you can run with aluminim heads vs octane? :)
Old Nov 12, 2002 | 04:08 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Compression Ratio vs Octane Table? (lead_foot)
Octane sensitivity is possibly too complex for a simple table.
It depends on head design, quench area and other factors controlling charge swirl along with CR. For example, if you went to a thinner head gasket, reducing quench, you would likely reduce octane sensitivity even though you would have a higher CR.
Old Nov 12, 2002 | 04:21 PM
vader86's Avatar
vader86
Yeah it depends on alot of things. What combo do you wish to run?
Generally more than say 11-11.5:1 is too high for pump gas.
Old Nov 12, 2002 | 04:24 PM
lead_foot's Avatar
lead_foot
Default Re: Compression Ratio vs Octane Table? (65Z01)
What I'm trying to do is get an idea of what the max (I realize that this could be off a little one way or the other) static compression ratio I could run in an L98 using 100 octane unleaded fuel. Just an estimate would be fine. Are we talking 11.5, 12, 12.5, 13 as a guess? If and when I actually head down this path I will work with a qualified, professional engine builder to make any final decisions. :)
Old Nov 12, 2002 | 04:26 PM
AS84's Avatar
AS84
Default Re: Compression Ratio vs Octane Table? (vader86)
in an old setup on our ford 422 I ran 12.3:1 at 36 degrees advance with no detonation on 93 octane.
Old Nov 12, 2002 | 04:42 PM
65Z01's Avatar
65Z01
Lingenfelter states that with Al heads 10.2:1 will run comfortably on pump gas, and that's with no mention of techniques to reduce octane sensitivity.
Old Nov 12, 2002 | 04:44 PM
jmr302's Avatar
jmr302
Default Re: Compression Ratio vs Octane Table? (AS84)
Was this with aluminum heads? I'm running Dart Iron Eagle heads with 11.2:1 compression. It detonates with 93 octane and 33 degrees advance.
Old Nov 13, 2002 | 09:10 AM
lead_foot's Avatar
lead_foot
Default Re: Compression Ratio vs Octane Table? (jmr302)
ttt
This would be with after market aluminum heads and using 100 octane fuel.
Old Nov 13, 2002 | 09:30 AM
Nathan Plemons's Avatar
Nathan Plemons
A friend of mine built a 396 that was supposed to be running around 12.5:1 compression and it didn't have any audible detonation. That doesn't mean the computer wasn't pulling timing, but if it was it wasn't pulling much because it ran like crazy. However this was on an LT1 and I've heard that the reverse flow cooling has a lot to do with it. The cooler cylinder heads are probably what allowed him to get away with it.
Old Nov 13, 2002 | 10:32 AM
AS84's Avatar
AS84
Yes, brodix track 1. I haven't ever driven it on the street in temps above 90...but on a high 70's degree night it would maintain 190 degrees. At the track I ran 110 in both fuel systems and 38 degrees advance NA and then pull 7 degrees out for a 250 shot.
To Compression Ratio vs Octane Table?
