RH power window switch wiring
I had to remove my passenger side door panel on my 1995 Vette. Before I could take the panel off I had to remove the power window switch. there was a plug I didn't find until latter. So I unplugged the 6 wires on the switch. I lost the paper that I showed where the wires that I pulled off went. Does anyone know how the wires go back on the switch? also the terminals on the switch aren't marked.
Second: Order a set of Factory Service Manuals for your particular year and it will have all the information you need in them. The sets of printed manuals are getting ridiculous, I was quoted $400 for the set for my daughters 2011 Camaro. I paid $15 on fleabay and got a whole set of books on a single DVD. Helm is the name of the publisher for the GM factory shop manuals. I have two of each set, one for the office and one for the garage.
There will hopefully be someone who has done the same thing or has the manuals to be able to help you with.
Is the switch on the left door a mirror image or the same as this one? I would open the left side and see if the parts are the same and that might help you with the wiring a bit.
I apologize as I have never seen anything like that part in my 1988 C4. Experienced help will be along in no time.
Hopefully this will be something simple for the right guy. I sincerely wish you the very best!
Best regards,
Chris
I took a picture before disconnecting. This is from my 96, but I verified wires were the same as my 93. Pretty sure 95/96 are the same
