94' Brake Light Issue
These LED lights have been installed since 2014 with no issues. I haven't had a chance to trouble shoot yet but plan to after work so was hoping you guys could give me a head start. I was going to check the fuses, lights themselves, as well as the brake pedal switch under the hush panel. Through a search I found that if the stop lamps aren't working but the third brake light is it can be related to the turn signal switch? I am almost thinking that is what it could be but its weird 1 little LED in the center of the third brake light strip is lighting up. If the LED Third brake light is malfunctioning could it lead to the others not working as well? A short perhaps?
I know its all speculation until I dig in but any thoughts or ideas?
