Power Window Question
Old Oct 7, 2019 | 11:48 AM
Hammerhead69's Avatar
Hammerhead69
Default Power Window Question
Ok so I still have the panel off the driver side door on my ‘89. My question is how much “play” should there be with the window. When it’s all the up it’s tight but if it’s about half way down there’s a lot of movement (It’s very loose, I can wiggle it quite a bit). Is this normal or are there bushings that are worn?
