1984 corvette does not idle
Old Oct 9, 2019 | 02:30 AM
gullo's Avatar
gullo
Cruising
Default 1984 corvette does not idle
Hi guys i have just brought a 1984 corvette i am having trouble with the idle after it has been driven for a while . as i slow down revs drop under 500 rpm and stalls 'i have installed new fuel sensors .engine runs well on highway can anyone give me some advice as to what it could be thanks gullo
Old Oct 9, 2019 | 08:10 AM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
Welcome to Corvette Forum. Your inquiry will be moved to the C4 Tech section. Good luck and enjoy your Corvette!
Old Oct 9, 2019 | 02:41 PM
Hot Rod Roy's Avatar
Hot Rod Roy
Originally Posted by gullo
I have installed new fuel sensors.
What sensors have you replaced? How did you determine these sensors were defective?
The engine idle speed should be controlled by the IAC's (Idle Air Controllers) that are located in the front of both throttle bodies. They may be dirty. They control the amount of air that bypasses the main butterfly throttle valves. Clean the tips of the IAC's and the ports in the throttle bodies. The air passage for the IAC's is the triangular opening in the top of the throttle body, just above the IAC location, which also needs to be clean. Don't turn on the ignition while the IAC's are not installed. The IAC's can't be moved by hand. It's normal that they seem to be stuck!
Old Oct 9, 2019 | 03:37 PM
gullo's Avatar
gullo
Cruising
Thanks for your reply
The IAC,s where replaced by my mechanic .I am still having the same problem
Old Oct 9, 2019 | 06:59 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
What fuel sensor are you talking about? Also, do you have a GM service manual? If not, get one. All that info on troublshooting is in there. Try eBay for the manual...DO NOT buy a Chillton manual, they are junk!
Old Oct 9, 2019 | 07:46 PM
Hot Rod Roy
The IAC's where replaced by my mechanic.
Why did your mechanic replace the IAC's? Was he happy with the performance of the car after replacing the IAC's?
Old Oct 9, 2019 | 09:58 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Your temperature sensor is bad. The L83 is very sensitive to the coolant temperature at it sends signals to the computer on rich/lean condition. This is common and the symptoms your describe says check the coolant sensor.
Old Oct 10, 2019 | 05:03 AM
GregMartin's Avatar
GregMartin
All good suggestions above. I can’t think what the fuel sensor your talking about could be. Do you mean the throttle position sensor TPS if so and you replaced it it needs to be adjusted. Off the top of my head I think it should measure 0.54 volts when the throttle is closed and something over 4.5 volts at WOT. (Ignition on engine off).
If the above recommendations don’t help then you could check the throttle body adjustment. The procedure is in the Factory Service Manual FSM. TBH I don’t think it’s adjustment because the symptoms would be different it might hunt at idle rather than just stall.
If you replace the Coolant Temperature Sensor CTS the new one will have an oval two pin plug which is a much better design. If it already has this plug it has been replaced.
You should also think of getting some sort of diagnostic scanner. For these cars a good option is the winALDL software which is free to download and use. The website also explains how to make a cable but there are pre-made options out there. You will be amaze at what you can see and diagnose with scanner software like winALDL.
Old Oct 10, 2019 | 03:26 PM
Hot Rod Roy
Adjusting the throttle bodies is the LAST, LAST, LAST thing on the list! I have 240,000 miles (386,000 km) on my '84, and the throttle bodies haven't been touched (other than spray carb cleaner), and it starts and runs fine!
Greg, have you discovered that the OP is also in Australia?
Old Oct 10, 2019 | 05:30 PM
GregMartin's Avatar
GregMartin
Agree Roy that they shouldn’t need adjustment but unlike your car a lot of these seem to have had the weld ground off and been messed with buy someone who doesn’t know what they are doing. That was the case with my car unfortunately.
Old Oct 10, 2019 | 05:32 PM
GregMartin's Avatar
GregMartin
Hey Gullo
Roy just pointed out that your are in Australia if you are anywhere near Brisbane I can give you a hand.
Old Oct 10, 2019 | 06:20 PM
Hot Rod Roy
Good point, but that needs be clarified for a new owner. If your throttle bodies have obviously been tampered with, maybe they're okay, but maybe not! Here's the "Weld" Greg is talking about:
Old Oct 12, 2019 | 02:05 AM
gullo's Avatar
gullo
Cruising
Hi Roy I live in sydney
This is my first corvette and could use some advise Maybe you could give me a call mob 0412411921
Thanks Chris Gullo CHEERS
Old Oct 12, 2019 | 10:01 AM
GregMartin's Avatar
GregMartin
Hi Chris
Its me (Greg) that lives in Brisbane. Roy lives in the US unless he has moved.
I’ll send you a message.
Old Oct 12, 2019 | 11:23 PM
Buccaneer's Avatar
Buccaneer
How far is Sydney from Brisbane, is it farther than the USA is long east to west?
Old Oct 13, 2019 | 12:28 AM
GregMartin's Avatar
GregMartin
Sydney is about 600 miles from Brisbane so I won’t be popping over to see him.
Very roughly Australia and the US are about the same size. Australia is bigger until you a Alaska then the US is.
So Sydney to Perth ie east cost to west coast is similar to LA to New York. About 5 hours in a plane.
Old Oct 15, 2019 | 12:14 AM
Buccaneer's Avatar
Buccaneer
To 1984 corvette does not idle
