L98 ignition timing
Old Oct 14, 2019 | 03:19 PM
JaredAwells's Avatar
JaredAwells
Default L98 ignition timing
I decided to reset my timing on my 1987 L98 after I put a new cap and rotor in it. I read in a few forums before doing so so I had a good idea of what to do what I did was I started the car and let it get up to temp I unplugged the tan/black wire thing and instantly the car started running rough so I quickly moved the distributor until it smoothed out after that I set it to 8 degrees advanced and shut the car off tightened the distributor down and I started the car to make sure I didn’t move it and it was still good so I shut it off plugged the tan/black wire back in and unhooked the battery for about 5 minutes and when I started it back up I checked the timing and it’s showing 30 plus degrees advanced what did I do wrong?
Old Oct 14, 2019 | 06:45 PM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
30 sounds high to me too, but keep in mind this is with the ECM controlling the timing now. Just checking, your comment wasn't clear, you did recheck after tightening the distributor, before reconnecting the..I forget, the tan/black thing.
One key point, DON'T unplug tan/black with the ignition on and certainly while the engine is running! I'm not 100%, but that certainly sounds risky to the ECM. Unplug, start up, set timing and finalize. Then stop, disengage battery and reconnect tan/black (boy, forgetting the name for that is bothering me!).
Finally, where did you get 8 degrees timing? I ask because my '87 calls for 6 degrees. The timing and how to set it should be listed on a sticker on the left side of the radiator, as it can vary due to options, etc.
Old Oct 14, 2019 | 08:35 PM
aklim's Avatar
aklim
With the tan wire connected, the ECM would probably be advancing it. AFAIK, timing should be set since you already did it and verified it.
Old Oct 14, 2019 | 08:40 PM
JaredAwells
I can’t remember the name of the tan and black wire either but I read that you can run 10 degrees advanced running 93 octane and you’re right it does recommend 6 I was going to try 8 to be a little conservative and just to see it it picks anything up
JaredAwells
Okay thank you
Old Oct 14, 2019 | 08:46 PM
mlm0's Avatar
mlm0
Your ecu is still thinking you are set at 6 degrees
Old Oct 14, 2019 | 09:33 PM
Hot Rod Roy's Avatar
Hot Rod Roy
It sounds to me like you've done it exactly right! The car should start and run fine with the static ignition timing set to 8 deg.
Old Oct 14, 2019 | 09:59 PM
jseremba's Avatar
jseremba
I believe it is called the EST Electronic Spark Timing
Old Oct 15, 2019 | 10:58 AM
vader86's Avatar
vader86
You set the base timing, which is 6-8 BTDC, with the EST disconnected.
Once you plug that back in, the ECM can now add its timing advance. Typically the total timing will be 30-45* depending on load/temperature/RPM conditions, these modifiers are added onto the timing the ECM normally runs from its memory in the chip.
So you did it right, sounds like. If you drive with a scanner connected and watch closely you'll see how it advances and pulls timing out.
Old Oct 15, 2019 | 11:46 AM
JaredAwells
okay thank you for the information
Old Oct 15, 2019 | 12:41 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
This.
What you did is exactly how I set up my race car. Im at 8-10° initial and then let the computer do the rest. Since there is no load on the engine at idle it can handle a surprising amount of timing. I think I am around 40°+ at idle and 36-38° at WOT.
Old Oct 15, 2019 | 03:04 PM
aklim's Avatar
aklim
Originally Posted by Kubs
This.
For a backyard hack, people have just cranked up the distributor but for a race car, would it not be better to change the advance in the eprom program?
Old Oct 15, 2019 | 03:39 PM
Hot Rod Roy
Initial base timing and eprom ignition program are two entirely different issues. Even if you have a custom eprom program, your initial base timing must be correct.
Old Oct 15, 2019 | 03:47 PM
aklim's Avatar
aklim
Don't disagree with the base timing but what I am curious about is why not set it for whatever and build the chip with that in mind? IOW, if you set base timing to 0 instead of 6 and build the program for with that in mind, would it not work? Say the engine needs 36 degrees, it puts the advance to 30 plus 6 base timing. Or could you not set it to 0 base and set up the advance to 36 thus giving it a total of 36? Or out another way, is there more than 1 way to skin the cat? Always wondered why GM chose 6 degrees base.
Old Oct 15, 2019 | 04:23 PM
aklim's Avatar
aklim
The OP's car is stock, so the factory ignition curve should be fine. Why the confusing talk about custom chips, custom race car specs, and arguing with GM's decision about base timing? These issues don't help the OP one bit! Please start your own thread if you want to fight with GM.
I'm just curious why Kubs did advance the timing for a race car. Also expressed a curiosity as to why GM decided on 6 degrees, not the more or less. Sorry I asked a question. Didn't know you would misinterpret it as fighting with GM. I forgot not to ask questions. Thanks for the reminder.
Old Oct 15, 2019 | 04:31 PM
Hot Rod Roy
what I am curious about is why not set it for whatever and build the chip with that in mind?.
Would it be any easier to set the base timing to 0 deg, than setting it to 6 deg.? Please don't answer this rhetorical question.
Old Oct 15, 2019 | 04:36 PM
aklim's Avatar
aklim
GM set base to 6. 302 Mustang is set to 10. My timing was set to 0 by accident BEFORE it was tuned. The tuner found out somehow AFTER he did the tune but assured me that the chip program was fine since it was based on whatever base was set at. If the distributor is removed or moved, I should set it for 0. Does that help you understand why I am curious as to what the rational was for 6 degrees and wondered if I should get it retuned with 6 degrees? Post happens to dig up old questions. Simply was curious about what way to proceed. I trust the turner's word. I just wanted to verify.
To L98 ignition timing
Old Oct 15, 2019 | 06:23 PM
Hot Rod Roy
Let's think about this. How can the ECU know where the "base" timing is set? There's no cam or crank position sensor in the L98 (or L83), so how can it know? Answer: It can't!
If the "base" timing is advanced X deg. from the factory recommended setting, the entire ignition curve will be advanced X deg. The various engine sensors will enter into the calculations for the final spark timing, but the factory curve will be whatever was programmed into the chip, with no consideration for the initial "base" timing! And there is nothing inside the distributor that advances the timing, unlike earlier HEI systems that had weights, springs, and vacuum. The final spark timing is strictly a function of the ECU.
If this were not true, you could set the initial "base" timing anywhere, and the engine would run exactly the same as if the "base" timing was set correctly! This is obviously not true.
Old Oct 15, 2019 | 06:55 PM
aklim's Avatar
aklim
IOW he was really telling the truth and that since he built the program around 0 degrees on the distributor, as long as I continue to time it at 0,the program is going to work right. Therefore, future timing sets should be set at 0 then? Good to know, if so.
Old Oct 15, 2019 | 07:38 PM
JaredAwells
dont mind me I’m learning from you guys as far as I understand I did it correctly and needs no further attention I enjoy learning this because some day when I get the money and time I am going to build it a little nothing to crazy
