1.6 and stack valve covers
Old Nov 14, 2002 | 02:38 PM
keekster's Avatar
keekster
Default 1.6 and stack valve covers
When you look inside the valve covers on a 92 there are 2 drip tabs next to ewach other one longer then the other. Do both come out ? Or just the longest one ?
Old Nov 14, 2002 | 04:31 PM
STL94LT1's Avatar
STL94LT1
Default Re: 1.6 and stack valve covers (keekster)
Cut them both off.
Old Nov 14, 2002 | 05:01 PM
95AquaC4's Avatar
95AquaC4
Default Re: 1.6 and stack valve covers (STL94LT1)
Cut them both off.
:yesnod:
Old Nov 15, 2002 | 12:06 AM
keekster's Avatar
keekster
2nd silly question. Whats the best way ?
Old Nov 15, 2002 | 11:34 AM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Use a cutoff wheel or Dremel tool with a cutoff wheel.
You can try to snap them off with a pair of pliers, but some have found that it can snap off more than they want and end up with a hole in the top of the valve cover.
After cutting the tabs off, clean the inside of the covers real good to get out all of the metal shavings.
Old Nov 16, 2002 | 04:43 PM
keekster's Avatar
keekster
How far down do they have to go ? Do they need to be flush ?
Old Nov 16, 2002 | 04:48 PM
STL94LT1's Avatar
STL94LT1
They don't have to be flush, just get them close.
Old Nov 17, 2002 | 09:45 AM
Rynda's Avatar
Rynda
Remember, your cutting magnesium. The chips are very flamible. No smokeing or open flames allowed. You don't need to cut all the way thru, you can score around them then snap them off with pliers.
To 1.6 and stack valve covers
