C4 Heavy Vibration under power
My dad bought this car sometime in the 2000's, then bought another black C4 as a parts car to fix it. At this time it had some kind of stroked motor in it. 2 and a half years ago that motor's crankshaft split down the middle and my dad bought a crate motor. This crate motor is a long block LT1 that makes around 500 horsepower on a good day. While this motor was on it's way, my dad passed away so my brother and I continued with the car. We bought a RAM clutch kit to replace the old clutch, specifically the 75-2175N kit. My brother did all the measurements and installed the clutch kit, and we bought a used transmission to fit into the car. Our first issue with the complete car was the flywheel, it was externally balanced while the engine was internally balanced on both sides. We got the flywheel surfaced and rebalanced, but the next issue was the C-Beam coming loose. After fixing that with some new bolts, we come to where I am now.
My guess is that the vibration is coming from the clutch kit or the transmission. The transmission makes a chattering noise too when power is added, but multiple sources say that the noise is normal. RAM Clutches called it "gear noise" in their video.
Any guesses? Whatever you might say is appreciated.
Zf6 has a rattle to it particularly in neutral. It's because of the clearance between the gears. It shouldn't rattle with any load. Engine and clutch assembly will vibrate with RPM. 1500 regardless or gear or speed. 55 is within a popular speed for driveshaft concerns...dampner and run out. Is dampner present and has it moved? Measure driveshaft run out front middle rear. Less than .010. If not flip it see if it changes.
Which dampener are you talking about? To measure the run-out I'd have to get a read indicator of some sort, though I think I know a shop that would measure it for me.
Old Tailshaft Bearing
Old slip yoke
I apologize if the pictures are larger than life. You can feel the scoring in the slip yoke and the bearing too. Maybe the lines are normal? I know the scoring in the yoke isn't normal.
I've got some recorded videos of the vibration I'm going to link.
When I get the lift back I'm pulling the bellhousing off and having it professionally balanced by a machine shop.
As far as the issue being the engine, I really can't see that. The engine we got was a long block with new injectors, and we bought new wires and plugs and a new optispark. I also really don't know what I'm doing so I could be wrong.
Thanks for the help so far, hopefully the issue gets fixed.
