BLM numbers?
Old Nov 14, 2002 | 10:52 PM
corvette4life's Avatar
corvette4life
Default BLM numbers?
My BLM numbers are 136 left bank and 132 right bank. Can I move these closer to the ideal 128 by adjusting fuel pressure? If so, should I raise or lower the pressure?
Thanks,
Kerry
Old Nov 14, 2002 | 10:57 PM
Greenvette's Avatar
Greenvette
Default Re: BLM numbers? (corvette4life)
the BLM numbers are lean. If you raise fuel pressure you will richen the fuel curve and move towards 128. However, I do not know if the L/R blms will close towards 128 evenly so both are reading 128. Is your vette stock?
Old Nov 15, 2002 | 09:31 AM
ZylaRace's Avatar
ZylaRace
The BLM #'s say the engine is running lean based on the programmed fuel map. By increasing the fuel pressure, you will add more fuel, so the ECM won't have to add more to the programmed fuel map. i.e. Your BLM's should back down, closer to 128. The low side of 128 seems to work best on acceleration.
To BLM numbers?
