1990 convertible, how do you remove the battery?
Old Nov 9, 2019 | 04:30 PM
1990vetteconvert's Avatar
1990vetteconvert
Default 1990 convertible, how do you remove the battery?
thanks
Old Nov 9, 2019 | 05:30 PM
markKlein's Avatar
markKlein
Originally Posted by 1990vetteconvert
thanks
Remove the side panel and slide it out sideways.
Old Nov 9, 2019 | 06:37 PM
Hot Rod Roy's Avatar
Hot Rod Roy
One trick: There's a bolt hiding in the slot at the bottom of the panel that needs to be loosened only. It needs a 10 mm open end wrench. The panel is slotted to allow you to remove the panel.
Old Nov 9, 2019 | 07:43 PM
CorvetteRules's Avatar
CorvetteRules
Here is a youtube vid
To 1990 convertible, how do you remove the battery?
