Racing Tranny.
Old Nov 15, 2002 | 02:19 PM
UB2 SLOW's Avatar
UB2 SLOW
From: I could tell but then I would have to kill you
Default Racing Tranny.
I am looking for a good racing tranny that could alos double as a daily driver. Can any sugest makes or models? I was told that there was a 4L80E that was good. I have a B&M shift kit in my 4L60E. I want it to be able to handle about 500hp+ at the engine. My goal is 400-420 rwhp.
Old Nov 15, 2002 | 03:11 PM
vader86's Avatar
vader86
Default Re: Racing Tranny. (UB2 SLOW)
Its not the HP, its the torque. There have been many threads on which tranny can hold up to the power output of our modded engines. A 700r4/4L60 can be beefed up to handle it, but you just have to find the right shop to do it. Eventually, the tranny will fail, even if its rated to handle more than youre putting out.
I would use a TH400/4L80, heavily beefed up. Thats what i'm looking at for the future.
Old Nov 15, 2002 | 03:57 PM
Matt383's Avatar
Matt383
From: 2003 Points Champ Great Lakes Corvette Challenge; 2006/2007 Winner MSD True Street
There was a discussion on this very subject a couple of days ago.
Click on this link.
http://forums.corvetteforum.com/zerothread?id=430213
Sounds like a couple members could help you.
I put in a turbo-400 pretty much for race. No overdrive. Drivable around town, but sucks on long highway drives due to high revs. Check out the discussion about gear vendors overdrive option. Good luck!
Old Nov 15, 2002 | 06:04 PM
UB2 SLOW's Avatar
UB2 SLOW
Default Re: Racing Tranny. (MJT383NO2)
Thanks MJT and Vader. :cheers:
Old Nov 15, 2002 | 07:26 PM
Sharky Guam's Avatar
Sharky Guam
MJT383NO2,
What did you do to convert the speedo drive? I want to do the same thing less the overdirve. I did one already, But I ended up putting an aftermarket mechanical speedo in. I wanted to retain the VSS thingy on the next conversion.
Old Nov 15, 2002 | 07:49 PM
qkvette's Avatar
qkvette
Default Re: Racing Tranny. (Sharky Guam)
does anybody have a partslist for a good 4l60 rebuild ?
thanks,
joel
To Racing Tranny.
