Do I need a Canton oil pan?
Old Nov 19, 2019 | 07:11 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I run a Canton pan and an accusump and I have zero issues with oil pressure in braking zones or hard corners. I also use mine to prelube the engine before start via an electric valve. While I haven't had any issues with my Canton pan, I have heard more complaints recently. If I were shopping again I would look at a Kevco.
Old Nov 19, 2019 | 07:52 AM
Aardwolf's Avatar
Aardwolf
First track event be sure to watch the water temp. I've seen these cars go home with head gasket problems.
Old Nov 19, 2019 | 11:25 AM
dizwiz24's Avatar
dizwiz24
no problems with mine but i havent tracked it ! (Which is pathetic i know)
Old Nov 19, 2019 | 01:45 PM
Joshie225's Avatar
Joshie225
I've done a hill climb and it was fine, but I will try to get it out locally (Portland International Raceway) for a good flog before the trip to Willow Springs. For some reason the car runs the primary cooling fan full time so it keeps temps in check pretty well. I know the relay hasn't been hot wired (hot grounded? :P) as I can command the fan off with EE Hack. I need to examine the bin to see why this is so. If someone changed the fan settings why would they run the cooling fan full time rather than just have it on at 190° or some such? And why leave the skip-shift on!? I will fix these things.
