hypertech or jet?
Old Nov 15, 2002 | 09:46 PM
zzz's Avatar
zzz
Default hypertech or jet?
I have an 86 with iron heads and the typical bolt-ons (intake, exhaust, 160 t-stat, MAT relocator, etc.). Will I get any improvement from a Hypertech or Jet chip? Should I go with their thermal chip version (i.e., requires a colder t-stat)? Or, just save my money?
Old Nov 15, 2002 | 10:15 PM
STL94LT1's Avatar
STL94LT1
Default Re: hypertech or jet? (zzz)
Very little, save your money.
Old Nov 16, 2002 | 08:20 AM
TA's Avatar
TA
Default Re: hypertech or jet? (STL94LT1)
Old Nov 16, 2002 | 10:30 AM
vader86's Avatar
vader86
both are a waste of money
Old Nov 16, 2002 | 11:38 AM
zzz's Avatar
zzz
Default Re: hypertech or jet? (vader86)
I think I'm hearing that both are a waste of money. :)
Old Nov 16, 2002 | 01:01 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
A custom chip can be useful for tuning to get the nth degree of power or when your mods are extensive.
Since you have mild mods and a MAF to measure air flow you only need adjust your AFPR to set fuel flow to match at WOT.
To control your fan around that 160 deg stat., install a HyperTech fan sw of the proper range into the aux fan switch position on the block.
So yes, the correct answer to your question is "neither". :yesnod:
To hypertech or jet?
