opti codes 92
Old Nov 16, 2002 | 12:03 PM
mjfox's Avatar
mjfox
Default opti codes 92
does anyone know what codes appear for misfire of opti problems
thanks mjfox
Old Nov 16, 2002 | 12:24 PM
cesar's Avatar
cesar
Default Re: opti codes 92 (mjfox)
code 16 is the usual one
Old Nov 16, 2002 | 01:26 PM
mjfox's Avatar
mjfox
Default Re: opti codes 92 (cesar)
i hooked up the cheap $30 gm code reader and it flashed once then break then two flashes
does anyone know what the book says on this
Old Nov 16, 2002 | 05:21 PM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
That's a 12, no codes stored. Check your wires and plugs, a simple tune up may be in order.
Old Nov 17, 2002 | 08:54 AM
PTz-92-LT1's Avatar
PTz-92-LT1
Default Re: opti codes 92 (92Shawnster)
Ditto on the 12 meaning no codes present and ditto on the give it a tune-up. However I might add that the Opti could very well be missing a little and not throw codes.
Old Nov 17, 2002 | 10:37 AM
Rick92's Avatar
Rick92
When mine quit there was no code like yours is doing!
Old Nov 17, 2002 | 01:31 PM
Goody's Avatar
Goody
Default Re: opti codes 92 (Rick92)
I have a slight miss with no codes stored as well. The OPTI only stores a code when it doesn't receive either one or two signals.
To opti codes 92
